So I am trying to install Garuda Wayfire on my pc however when I select the free drivers in the grub menu and boot into the OS the mouse cursor is not visible. The reasoning behind choosing the free drivers is that if I choose the non-free ones the OS does not boot it just stays at starting Garuda Wayfire. Is there any work arounds to make the mouse cursor appear?
So I have looked at that post previously but I am not sure as to how to apply that. Forgive me I am still kind of new to Linux as a whole. Any help is appreciated thanks.
I suppose I should have my bad . So in reference to ~/. profile how do I run the command there, sorry if I am not understanding like I said I am a noobie in Linux in certain areas. Just trying to get this figured out so I can install and learn more as I go.
I will give this a try, hopefully I can get it from my understanding of it. I am curious as to what would even cause this issue, I read it had something to do with the nouveau driver.
You're in a live (transient/temporary/impermanent/...) environment so any changes you make will be lost after a reboot. This is by design, intentional, and not something which can be fixed.
Just out of interest, why did you choose the Wayfire edition as your starting point? It's not what I would call a "noobie" choice?
Right I'm aware as nothing is permanent in a live installation environment. And as far as why I chose Wayfire I liked the look and functionality of it, I'm coming from Arch linux installation I setup myself with the help of the wiki but I was just looking for a Arch based OS that had what I needed and maybe potentially learn more from it. I figured I'd jump into Wayfire. I know my way around some of linux functionality and commands but other areas not so much.
