: Synchronizing package databases...
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
error: could not open file /var/lib/pacman/local/brave-bin-1:1.47.171-1/desc: No such file or directory
resolving dependencies...
warning: ignoring package pipewire-common-git-0.3.66.r28.gda21cfa9-1
warning: could not fully load metadata for package brave-bin-1:1.47.171-1
error: failed to prepare transaction (invalid or corrupted package)
Press enter to exit
Welcome ![]()
Hi,
I edit your text, please use
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text in the view. Move the mouse pointer over it in the upper right corner.
Please, post always the input (command) and output from TERMINAL.
Did you use
garuda-update
if not, use it.
BTW, missing your
Brave sure does seem to be a problem child.
Try applying this tutorial:
