Hi all,
My system is missing few icons and I’m not able to figure out what can be wrong.
I’m missing the dragon icon on the top left corner (Garuda KDE Dr460nized
) and few others in my terminal of choice, Yakuake. To be more precise I miss the emoji for the root user and the crescent of lua:
All the icons I’m missing in Yakuake can be rendered In Konsole though.
I’ve found a very similar topic from 2021 ( Missing icons 🐉) but the accepted solution did not work for me: I tried to create a local.conf file in /etc/fonts with the suggested content but it didn’t work.
My garuda-inxi is the following:
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cb2ded22-b906-4231-848c-561f155dfdd4 rw rootflags=subvol=@
resume=UUID=80c361fe-abbd-4583-93d4-0b8f4261812e loglevel=3
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Acer product: Nitro AN515-43 v: V1.08
Mobo: PK model: Octavia_PKS v: V1.08 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.08
date: 12/24/2019
ID-1: BAT1 charge: 33.3 Wh (94.3%) condition: 35.3/57.5 Wh (61.4%)
volts: 16.4 min: 15.4 model: LG 0x41,0x50,0x31,0x38,0x45,0x38,0x4D
type: Li-ion serial: <filter> status: charging
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2575 high: 3937 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2561 2: 2056
3: 3739 4: 3937 5: 1520 6: 1537 7: 2637 8: 2616 bogomips: 36730
Device-1: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 555.58.02
2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 65.0 C
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0408:a061
class-ID: 0e02
gpu: nvidia,amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: HDMI-A-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 10 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.57 6.10.6-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Vega 10 Graphics (RADV RAVEN) driver: mesa radv v: 24.1.6-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1050 Ti driver: nvidia
v: 555.58.02 device-ID: 10de:1c8c surfaces: xcb,xlib,wayland device: 2
v: 24.1.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 33.0 C
IF-ID-2: virbr1 state: down mac: <filter>
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 04ca:3016 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.26 TiB used: 101.23 GiB (7.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 80002C00 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: ACM1 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 115.5 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
used: 101.23 GiB (45.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
ID-4: /var/log raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.22 GiB size: 223.22 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 1.5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 14.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 64.4 C mobo: N/A gpu: amdgpu temp: 64.0 C
Memory: total: 16 GiB note: est. available: 13.59 GiB used: 4.47 GiB (32.9%)
Processes: 304 Power: uptime: 25m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.37 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1709 libs: 465 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32
running-in: yakuake inxi: 3.3.35
System install date: 2022-09-11
Last full system update: 2024-08-25
Please also see below my fc-conflist:
╭─daniel@garuda in ~ took 3s
╰─λ fc-conflist
+ /etc/fonts/conf.d/10-hinting-slight.conf: Set hintslight to hintstyle
+ /etc/fonts/conf.d/10-scale-bitmap-fonts.conf: Bitmap scaling
+ /etc/fonts/conf.d/10-sub-pixel-rgb.conf: Enable sub-pixel rendering with the RGB stripes layout
+ /etc/fonts/conf.d/10-yes-antialias.conf: Enable antialiasing
+ /etc/fonts/conf.d/11-lcdfilter-default.conf: Use lcddefault as default for LCD filter
+ /etc/fonts/conf.d/20-unhint-small-dejavu-lgc-sans-mono.conf: No description
+ /etc/fonts/conf.d/20-unhint-small-dejavu-lgc-sans.conf: No description
+ /etc/fonts/conf.d/20-unhint-small-dejavu-lgc-serif.conf: No description
+ /etc/fonts/conf.d/20-unhint-small-dejavu-sans-mono.conf: No description
+ /etc/fonts/conf.d/20-unhint-small-dejavu-sans.conf: No description
+ /etc/fonts/conf.d/20-unhint-small-dejavu-serif.conf: No description
+ /etc/fonts/conf.d/20-unhint-small-vera.conf: Disable hinting for Bitstream Vera fonts when the size is less than 8ppem
+ /etc/fonts/conf.d/30-metric-aliases.conf: Set substitutions for similar/metric-compatible families
+ /etc/fonts/conf.d/40-nonlatin.conf: Set substitutions for non-Latin fonts
+ /etc/fonts/conf.d/45-generic.conf: Set substitutions for emoji/math fonts
+ /etc/fonts/conf.d/45-latin.conf: Set substitutions for Latin fonts
+ /etc/fonts/conf.d/46-noto-mono.conf: No description
+ /etc/fonts/conf.d/46-noto-sans.conf: No description
+ /etc/fonts/conf.d/46-noto-serif.conf: No description
+ /etc/fonts/conf.d/48-spacing.conf: Add mono to the family when spacing is 100
+ /etc/fonts/conf.d/49-sansserif.conf: Add sans-serif to the family when no generic name
+ /home/daniel/.fonts.conf: No description
+ /etc/fonts/conf.d/50-user.conf: Load per-user customization files
+ /etc/fonts/local.conf: No description
+ /etc/fonts/conf.d/51-local.conf: Load local customization file
+ /etc/fonts/conf.d/57-dejavu-sans-mono.conf: No description
+ /etc/fonts/conf.d/57-dejavu-sans.conf: No description
+ /etc/fonts/conf.d/57-dejavu-serif.conf: No description
+ /etc/fonts/conf.d/58-dejavu-lgc-sans-mono.conf: No description
+ /etc/fonts/conf.d/58-dejavu-lgc-sans.conf: No description
+ /etc/fonts/conf.d/58-dejavu-lgc-serif.conf: No description
+ /etc/fonts/conf.d/60-generic.conf: Set preferable fonts for emoji/math fonts
+ /etc/fonts/conf.d/60-latin.conf: Set preferable fonts for Latin
+ /etc/fonts/conf.d/65-fonts-persian.conf: No description
+ /etc/fonts/conf.d/65-nonlatin.conf: Set preferable fonts for non-Latin
+ /etc/fonts/conf.d/66-noto-mono.conf: No description
+ /etc/fonts/conf.d/66-noto-sans.conf: No description
+ /etc/fonts/conf.d/66-noto-serif.conf: No description
+ /etc/fonts/conf.d/69-unifont.conf: No description
+ /etc/fonts/conf.d/69-urw-bookman.conf: No description
+ /etc/fonts/conf.d/69-urw-c059.conf: No description
+ /etc/fonts/conf.d/69-urw-d050000l.conf: No description
+ /etc/fonts/conf.d/69-urw-fallback-backwards.conf: No description
+ /etc/fonts/conf.d/69-urw-fallback-generics.conf: No description
+ /etc/fonts/conf.d/69-urw-fallback-specifics.conf: No description
+ /etc/fonts/conf.d/69-urw-gothic.conf: No description
+ /etc/fonts/conf.d/69-urw-nimbus-mono-ps.conf: No description
+ /etc/fonts/conf.d/69-urw-nimbus-roman.conf: No description
+ /etc/fonts/conf.d/69-urw-nimbus-sans.conf: No description
+ /etc/fonts/conf.d/69-urw-p052.conf: No description
+ /etc/fonts/conf.d/69-urw-standard-symbols-ps.conf: No description
+ /etc/fonts/conf.d/69-urw-z003.conf: No description
+ /etc/fonts/conf.d/75-yes-terminus.conf: No description
+ /etc/fonts/conf.d/80-delicious.conf: No description
+ /etc/fonts/conf.d/90-synthetic.conf: No description
+ /etc/fonts/fonts.conf: Default configuration file
- /usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf: Re-define fonts dirs sample
- /usr/share/fontconfig/conf.avail/09-autohint-if-no-hinting.conf: Enable autohinter if font doesn't have any hinting
- /usr/share/fontconfig/conf.avail/10-autohint.conf: Enable autohinter
- /usr/share/fontconfig/conf.avail/10-hinting-full.conf: Set hintfull to hintstyle
- /usr/share/fontconfig/conf.avail/10-hinting-medium.conf: Set hintmedium to hintstyle
- /usr/share/fontconfig/conf.avail/10-hinting-none.conf: Set hintnone to hintstyle
- /usr/share/fontconfig/conf.avail/10-hinting-slight.conf: Set hintslight to hintstyle
- /usr/share/fontconfig/conf.avail/10-no-antialias.conf: Disable antialiasing
- /usr/share/fontconfig/conf.avail/10-scale-bitmap-fonts.conf: Bitmap scaling
- /usr/share/fontconfig/conf.avail/10-sub-pixel-bgr.conf: Enable sub-pixel rendering with the BGR stripes layout
- /usr/share/fontconfig/conf.avail/10-sub-pixel-none.conf: Disable sub-pixel rendering
- /usr/share/fontconfig/conf.avail/10-sub-pixel-rgb.conf: Enable sub-pixel rendering with the RGB stripes layout
- /usr/share/fontconfig/conf.avail/10-sub-pixel-vbgr.conf: Enable sub-pixel rendering with the vertical BGR stripes layout
- /usr/share/fontconfig/conf.avail/10-sub-pixel-vrgb.conf: Enable sub-pixel rendering with the vertical RGB stripes layout
- /usr/share/fontconfig/conf.avail/10-unhinted.conf: Disable hinting
- /usr/share/fontconfig/conf.avail/10-yes-antialias.conf: Enable antialiasing
- /usr/share/fontconfig/conf.avail/11-lcdfilter-default.conf: Use lcddefault as default for LCD filter
- /usr/share/fontconfig/conf.avail/11-lcdfilter-legacy.conf: Use lcdlegacy as default for LCD filter
- /usr/share/fontconfig/conf.avail/11-lcdfilter-light.conf: Use lcdlight as default for LCD filter
- /usr/share/fontconfig/conf.avail/11-lcdfilter-none.conf: Use lcdnone as default for LCD filter
- /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-lgc-sans-mono.conf: No description
- /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-lgc-sans.conf: No description
- /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-lgc-serif.conf: No description
- /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-sans-mono.conf: No description
- /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-sans.conf: No description
- /usr/share/fontconfig/conf.avail/20-unhint-small-dejavu-serif.conf: No description
- /usr/share/fontconfig/conf.avail/20-unhint-small-vera.conf: Disable hinting for Bitstream Vera fonts when the size is less than 8ppem
- /usr/share/fontconfig/conf.avail/25-unhint-nonlatin.conf: Disable hinting for CJK fonts
- /usr/share/fontconfig/conf.avail/30-metric-aliases.conf: Set substitutions for similar/metric-compatible families
- /usr/share/fontconfig/conf.avail/35-lang-normalize.conf: No description
- /usr/share/fontconfig/conf.avail/40-nonlatin.conf: Set substitutions for non-Latin fonts
- /usr/share/fontconfig/conf.avail/45-Hack.conf: No description
- /usr/share/fontconfig/conf.avail/45-generic.conf: Set substitutions for emoji/math fonts
- /usr/share/fontconfig/conf.avail/45-latin.conf: Set substitutions for Latin fonts
- /usr/share/fontconfig/conf.avail/46-noto-mono.conf: No description
- /usr/share/fontconfig/conf.avail/46-noto-sans.conf: No description
- /usr/share/fontconfig/conf.avail/46-noto-serif.conf: No description
- /usr/share/fontconfig/conf.avail/48-spacing.conf: Add mono to the family when spacing is 100
- /usr/share/fontconfig/conf.avail/49-sansserif.conf: Add sans-serif to the family when no generic name
- /usr/share/fontconfig/conf.avail/50-user.conf: Load per-user customization files
- /usr/share/fontconfig/conf.avail/51-local.conf: Load local customization file
- /usr/share/fontconfig/conf.avail/57-dejavu-sans-mono.conf: No description
- /usr/share/fontconfig/conf.avail/57-dejavu-sans.conf: No description
- /usr/share/fontconfig/conf.avail/57-dejavu-serif.conf: No description
- /usr/share/fontconfig/conf.avail/58-dejavu-lgc-sans-mono.conf: No description
- /usr/share/fontconfig/conf.avail/58-dejavu-lgc-sans.conf: No description
- /usr/share/fontconfig/conf.avail/58-dejavu-lgc-serif.conf: No description
- /usr/share/fontconfig/conf.avail/60-generic.conf: Set preferable fonts for emoji/math fonts
- /usr/share/fontconfig/conf.avail/60-latin.conf: Set preferable fonts for Latin
- /usr/share/fontconfig/conf.avail/65-fonts-persian.conf: No description
- /usr/share/fontconfig/conf.avail/65-khmer.conf: No description
- /usr/share/fontconfig/conf.avail/65-nonlatin.conf: Set preferable fonts for non-Latin
- /usr/share/fontconfig/conf.avail/66-noto-mono.conf: No description
- /usr/share/fontconfig/conf.avail/66-noto-sans.conf: No description
- /usr/share/fontconfig/conf.avail/66-noto-serif.conf: No description
- /usr/share/fontconfig/conf.avail/69-unifont.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-bookman.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-c059.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-d050000l.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-fallback-backwards.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-fallback-generics.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-fallback-specifics.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-gothic.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-nimbus-mono-ps.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-nimbus-roman.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-nimbus-sans.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-p052.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-standard-symbols-ps.conf: No description
- /usr/share/fontconfig/conf.avail/69-urw-z003.conf: No description
- /usr/share/fontconfig/conf.avail/70-no-bitmaps.conf: Reject bitmap fonts
- /usr/share/fontconfig/conf.avail/70-yes-bitmaps.conf: Accept bitmap fonts
- /usr/share/fontconfig/conf.avail/75-noto-color-emoji.conf: No description
- /usr/share/fontconfig/conf.avail/75-yes-terminus.conf: No description
- /usr/share/fontconfig/conf.avail/80-delicious.conf: No description
- /usr/share/fontconfig/conf.avail/90-synthetic.conf: No description
I don’t remember ever playing around with the fonts and I vaguely remember this might have been broken since the KDE 6 upgrade, although I might be wrong on that.
Can someone please help me how can I fix this?
Thanks a lot!
