groot
1 February 2024 10:54
1
Hello Garuda users
I’m using Lenovo Thinkpad T440s
I can’t find solution to a little problem. Can’t see Display & Monitor settings.
When using Garuda Welcome I can enter into Garuda Settings Manager and from there can see:
Install drivers, change kernel and change language packs in Hardware section
User accounts, time and date, keyboard settings and local settings in System section
And thats all settings I could change?
Tried to search for on my own but without luck (or maybe with bad phrase). Can anyone guide me a bit?
SGS
1 February 2024 11:53
2
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
lxrandr or arandr
groot
1 February 2024 12:28
3
Here is missing inxi
Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b9f1014a-ef35-4e6b-9c54-83cf70026aad rw rootflags=subvol=@
quiet resume=UUID=1637ae88-da0a-4feb-8b41-e0f718d15e6e loglevel=3 ibt=off
Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 20ARS0B10B v: ThinkPad T440s
Mobo: LENOVO model: 20ARS0B10B v: 0B98401 PRO serial: <superuser required>
UEFI: LENOVO v: GJET94WW (2.44 ) date: 09/14/2017
ID-1: BAT0 charge: 17.3 Wh (99.4%) condition: 17.4/23.2 Wh (75.0%)
volts: 12.3 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
status: not charging
ID-2: BAT1 charge: 19.0 Wh (99.5%) condition: 19.1/23.5 Wh (81.1%)
volts: 12.7 min: 11.4 model: LGC 45N1127 type: Li-ion serial: <filter>
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1599 high: 1964 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1964 2: 819 3: 1720
4: 1896 bogomips: 19952
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:4 chip-ID: 04f2:b39a
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 compositor: Picom v: git-fc1d1
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: crocus
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: AU Optronics 0x303e built: 2012 res: 1600x900
hz: 60 dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1600x900
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 4400 (HSW GT2) driver: mesa intel v: 23.3.4-arch1.2
device-ID: 8086:0a16 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.4-arch1.2 (LLVM
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo 8 driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:3 chip-ID: 8087:07dc
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 592.37 GiB used: 15.73 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: HP model: SSD S700 Pro 512GB
size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Wilk model: USB 3.2 gen. 1
size: 115.43 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 102.41 GiB size: 102.41 GiB (100.00%)
used: 15.73 GiB (15.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 102.41 GiB size: 102.41 GiB (100.00%)
ID-4: /var/log raw-size: 102.41 GiB size: 102.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 102.41 GiB size: 102.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.56 GiB used: 123 MiB (1.0%) priority: 100
ID-2: swap-2 type: partition size: 12.72 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2978
Processes: 225 Uptime: 5h 41m wakeups: 0 Memory: total: 12 GiB
available: 11.56 GiB used: 3.07 GiB (26.6%) Init: systemd v: 255
pm: pacman pkgs: 1435 libs: 421 tools: octopi,paru Shell: Bash v: 5.2.26
running-in: kitty inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-31
Last full system update: 2024-02-01 ↻
groot
1 February 2024 12:39
4
Just noticed one thing apart of this post problem. Inxi batery section says status: not charging but charger was pluged in. Weird thing
SGS
1 February 2024 12:48
5
Just reboot
groot:
Self-protection?
I load only up to 60% via app/lenovo settings
You can use arandr for monitor settings or set Xft.dpi: 120 in .Xresources
120 is just a sample.
groot
1 February 2024 15:21
6
OK, just rebooted OS and here is new inxi.
Kernel: 6.7.2-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
ID-1: BAT0 charge: 17.2 Wh (98.9%) condition: 17.4/23.2 Wh (75.0%)
ID-2: BAT1 charge: 8.7 Wh (45.8%) condition: 19.0/23.5 Wh (81.1%)
power: 12.2 W volts: 11.1 min: 11.4 model: LGC 45N1127 type: Li-ion
Speed (MHz): avg: 1212 high: 1578 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1053 2: 1420 3: 798
4: 1578 bogomips: 19952
class-ID: 0e02
API: ALSA v: k6.7.2-zen1-2-zen status: kernel-api tools: N/A
Local Storage: total: 592.37 GiB used: 15.74 GiB (2.7%)
used: 15.74 GiB (15.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: zram size: 11.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2972
Processes: 225 Uptime: 32m wakeups: 0 Memory: total: 12 GiB
available: 11.56 GiB used: 2.82 GiB (24.4%) Init: systemd v: 255
pm: pacman pkgs: 1434 libs: 421 tools: octopi,paru Shell: Bash v: 5.2.26
Garuda (2.6.22-1):
Failed units: session-c1.scope
With arandr monitor settings can be changed. What about display setting like night color? Is there some way to set this option?
SGS
1 February 2024 15:33
7
Redshift or something, I don’t use it.
groot
1 February 2024 15:37
8
Redshift is interesting app. Thank you
system
Closed
3 February 2024 15:38
9
