Hi
yay package in chaotic-aur misses a dependency: "go" package is required for yay to work since it's written in go.
current dependnecies of yay package in chaotinc-aur rep:
https://bin.garudalinux.org/?8bdc554a7d736592#3fRFh89jRyn1AsENbd3frmguuYVHwD9As3sgiWbFNzih
yay work fine here, post output from terminal
yay
❯ sudo pacman -Qi yay 86% ─╯
[sudo] password for amir:
Sorry, try again.
Version : 10.1.2-1
Description : Yet another yogurt. Pacman wrapper and AUR helper written in
go.
Architecture : x86_64
URL : https://github.com/Jguer/yay
Licenses : GPL
Groups : None
Provides : None
Depends On : pacman>5 sudo git
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 7.97 MiB
Packager : Pedro Henrique Lara Campos <root@pedrohlc.com>
Build Date : Sat 26 Dec 2020 04:03:27 AM +0330
Install Date : Wed 06 Jan 2021 12:02:51 AM +0330
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
Small text file you can post here, read
and
Go links statically by default, and yay is no exception, therefore its executable has no runtime dependencies.
In simple human language , in AUR package, they use
go
as a dependency for building the package only, meaning it is not needed after the package is built.
Chaotic-aur packages are already built, so there is no need for go
to install or run yay
