[System info]
I am facing an issue with my boot entry I have 3 OS In my system :
1)Ubuntu 2 )Garuda 3)Arch
and I have 2 kernels in my garuda, arch and ubuntu :
1)Linux
2)linux-zen
and I installed them in the following order :
sda1: grub (boot/EFI)
sda2: Ubantu (/)
sda3: Garuda (/)
sda4: Arch (/)
sda5: storage (BTRFS)
sda6: swap (Linux swap)
[Problem]
So the main problem is I am unable to get all the entries in the same boot loader
I have Ubuntu and Garuda in my boot menu but Arch is not registered
I don't see any entry for changing my kernel in the boot menu
[Things I had tried]
yes I tried to update-grub with the following command but it doesn't fix it :
sudo grub-mkconfig -o /boot/grub/grub-btrfs.cfg
sudo update-grub
[Summary ]
I want to add all my os and all the kernel listed in grub like:
garuda Linux
garuda Linux-zen
Ubuntu
ubuntu Linux-zen
Arch Linux
Arch Linux-zen
λ sudo update-grub
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img
Found Ubuntu 22.04.2 LTS on /dev/sda2
Found Garuda Linux on /dev/sda3
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-02-18 11:03:48 | timeshift-btrfs/snapshots/2023-02-18_11-03-48/@ | ondemand | N/A |
Found snapshot: 2023-02-18 06:29:05 | timeshift-btrfs/snapshots/2023-02-18_06-29-05/@ | ondemand | N/A |
Found 2 snapshot(s)
Unmount /tmp/grub-btrfs.dx5HILX3ni .. Success
done
Ubantu :
sudo update-grub
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Found linux image: /boot/vmlinuz-5.19.0-35-generic
Found initrd image: /boot/initrd.img-5.19.0-35-generic
Found linux image: /boot/vmlinuz-5.15.0-43-generic
Found initrd image: /boot/initrd.img-5.15.0-43-generic
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Found Arch Linux on /dev/sda4
done
Arch :
~> sudo grub-mkconfig -o /boot/grub/grub.cfg
[sudo] password for kamal:
done
