Missing audio and webcam on 2017 iMacPro
With Apple’s announcement that older intel macs would be orphaned, I decided to try to get linux working on it before HAD to.
My problem appears to be driver and hardware detection failure as I have no sound and no webcam.
This situation smells like the t2 situation discussed for those macs newer than 2018, however mine is older.
Can someone point me the the correct direction, I’m struggling to find something to read that makes me confident I’m in the right place.
pointers appreciated please
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=3df749af-f362-49d3-bc50-6de6cd6733ef rw rootflags=subvol=@
Type: Laptop System: Apple product: iMacPro1,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-7BA5B2D9E42DDD94
Mobo: Apple model: Mac-7BA5B2D9E42DDD94 v: iMacPro1,1
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 2075.120.2.0.0 (iBridge: 22.16.15072.0.0,0) date: 04/25/2025
Info: model: Intel Xeon W-2140B bits: 64 type: MT MCP arch: Skylake
level: v4 note: check process: Intel 14nm family: 6 model-id: 0x55 (85)
stepping: 4 microcode: 0x2007006
desc: 8x1024 KiB L3: 11 MiB desc: 1x11 MiB
Speed (MHz): avg: 1200 min/max: 1200/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200 13: 1200 14: 1200
15: 1200 16: 1200 bogomips: 102399
Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 XL [Radeon Pro 56]
vendor: Apple driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: DP-2,DP-3,eDP-1 empty: DP-1,DP-4,DP-5 bus-ID: f3:00.0
chip-ID: 1002:6867 class-ID: 0300
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5760x2160
display-ID: 0
Monitor-1: DP-2 pos: bottom-r model: HP E232 serial: <filter> built: 2016
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: DP-3 pos: primary,top-left model: HP E232 serial: <filter>
built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
Monitor-3: eDP-1 pos: top-center model: Apple iMac serial: <filter>
built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 163 gamma: 1.2
max: 3840x2160 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
vega10 ACO DRM 3.63 6.15.4-zen2-1-zen) device-ID: 1002:6867
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon Graphics (RADV VEGA10) driver: mesa radv v: 25.1.4-arch1.1
device-ID: 1002:6867 surfaces: N/A device: 1 type: cpu name: llvmpipe
Device-1: Apple Audio driver: N/A pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 02:00.3 chip-ID: 106b:1803 class-ID: 0401
Device-2: Advanced Micro Devices [AMD/ATI] Vega 10 HDMI Audio [Radeon
56/64] driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: f3:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-3: Shokz Loop110 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.3.1:7
chip-ID: 3511:2b0a class-ID: 0102 serial: <filter>
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM4364 802.11ac Wireless Network Adapter vendor: Apple
driver: N/A modules: brcmfmac pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 14e4:4464 class-ID: 0280
Device-2: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: Apple driver: atlantic v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s port: N/A bus-ID: 04:00.0
chip-ID: 1d6a:07b1 class-ID: 0200 temp: 53.9 C
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
Local Storage: total: 931.84 GiB used: 61.98 GiB (6.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD AP1024M
size: 931.84 GiB block-size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 1310
temp: 29.9 C scheme: GPT
ID-1: / raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
used: 61.98 GiB (6.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
used: 644 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
ID-4: /var/log raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.06 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 39.0 C
Memory: total: 32 GiB note: est. available: 31.06 GiB used: 4.69 GiB (15.1%)
Processes: 432 Power: uptime: 1h 38m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: shutdown
avail: reboot,suspend,test_resume image: 12.4 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 2219 libs: 477 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2025-06-27
Last full system update: 2025-07-01 ↻
I did not find your Mac :frowning:
Did you check all in the above arch wiki?
I didn’t find it either. I’ll try posting on the Arch forum and see.
After a little more digging, I found confirmation from apple that this model does in fact have the t2 chip. I’ll work on a kernel change as discussed and report back.
For sound you need the cs804 driver (aur package snd-hda-macbookpro-dkms-git)
To install over paru -S snd-hda-macbookpro-dkms-git
For webcam the facetime driver.
sudo pacman -S facetimehd-dkms
reboot and result = ?
To read for info
