Great day community,
I have this small issue regarding fastfetch which displays when I open up my terminal (tabby). I've stumbled upon on this thread where there is a snippet of config by @SGS to show up dragon (which I think looks super cool) instead of ASCII G.
## Run fastfetch if session is interactive
if status --is-interactive && type -q fastfetch
fastfetch --load-config garuda
end
I've tried both included snippets, --load-config garuda and --load-config dr460nized. Now, when I start my terminal, it'll display my system info as usual, but there is no icon at all, there is just a blank space - no ASCII G, no dragon.
This is not an issue really, I can always revert back to neofetch, but any help would be - as always - greatly appreciated.
inxi:
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw [email protected]
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3 ibt=off
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <superuser required> UEFI: AMI
v: F.22 date: 05/03/2021
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 999 high: 1000 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 1000 3: 1000
4: 999 5: 1000 6: 1000 7: 1000 8: 1000 9: 1000 10: 1000 11: 1000 12: 997
bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04ca:707f
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 compositors:
1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 142
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: ztksey564h state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0029
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.84 TiB used: 126.37 GiB (6.7%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS0NEXF temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
used: 126.35 GiB (14.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 29.4 MiB (11.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C pch: 57.0 C mobo: N/A gpu: nvidia
temp: 52 C
Fan Speeds (RPM): cpu: 1987 fan-2: 0
Processes: 382 Uptime: 3h 54m wakeups: 1 Memory: available: 31.23 GiB
used: 11.75 GiB (37.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1838
libs: 530 tools: pamac,paru,yay Shell: fish v: 3.6.1 running-in: tabby
inxi: 3.3.27
System install date: 2021-07-24
Last full system update: 2023-05-16 ↻
Relevant software: timeshift tlp NetworkManager mkinitcpio nvidia-dkms
