You asked for this:
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e12d414f-bc5b-45e2-a650-04757c7cc293 rw rootflags=subvol=@
resume=UUID=3919f716-9d3e-469a-8f0b-0b966d414692 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <filter> part-nu: SKU uuid: ee126047-107c-3cc9-6292-7c10c93c6291
UEFI: American Megatrends v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3700 min/max: 2200/4950 boost: enabled
base/boost: 3700/4950 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 3700
13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 3700 20: 3700
21: 3700 22: 3700 23: 3700 24: 3700 bogomips: 177584
vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 0c:00.0 chip-ID: 1002:73df class-ID: 0300
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 model: Dell S2421NX serial: <filter> built: 2021
res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 530x300mm (20.87x11.81")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.2
navi22 LLVM 17.0.6 DRM 3.57 6.7.9-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.2-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:6 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 157.19 TiB used: 143.28 TiB (91.1%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Corsair model: MP600 PRO
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM21.1 temp: 42.9 C
SMART: yes health: PASSED on: 2y 33d 14h cycles: 110
read-units: 331,400,067 [169 TB] written-units: 1,721,544,577 [881 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.2 temp: 41.9 C
SMART: yes health: PASSED on: 3y 124d 8h cycles: 193
read-units: 96,019,876 [49.1 TB] written-units: 222,351,277 [113 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWG21C
family: N300/MN NAS HDD size: 10.91 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 0601 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 26d 22h cycles: 75
Pre-Fail: reallocated sector: 100 threshold: 50
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1050MX300SSD1
family: Micron Client SSDs size: 978.09 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: R040 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 111d 3h cycles: 399
written: 397.71 TiB
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD6400AACS-00G8B0 family: Caviar Green size: 596.17 GiB block-size:
physical: 512 B logical: 512 B sata: 2.5 speed: 3.0 Gb/s tech: N/A
serial: <filter> fw-rev: 4C05 temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 13y 246d 14h cycles: 805
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST4000VX016-3CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: CV10
temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 16d 9h cycles: 13
read: 51.44 TiB written: 4.92 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-7: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 980 PRO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1.00 drive-rev: 5B2QGXA7 temp: 35 Celsius C scheme: GPT
SMART: yes health: PASSED on: 113d 11h cycles: 736
read-units: 9,785,723 [5.01 TB] written-units: 48,487,620 [24.8 TB]
ID-8: /dev/sdf maj-min: 8:80 vendor: Seagate model: Backup+ Hub BK
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: D785 scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-9: /dev/sdg maj-min: 8:96 vendor: Seagate model: Backup+ Hub BK
fw-rev: D781 scheme: GPT
ID-10: /dev/sdh maj-min: 8:112 vendor: Seagate model: Backup+ Hub BK
ID-11: /dev/sdi maj-min: 8:128 vendor: Western Digital
model: WD101EDBZ-11B1DA0 size: 9.1 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 3.2 speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1031 drive-rev: 85.00A85 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 170d 12h cycles: 3301
ID-12: /dev/sdj maj-min: 8:144 model: USB Disk 3.0 size: 116.21 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0000
ID-13: /dev/sdk maj-min: 8:160 vendor: SanDisk model: ST8000DM004-2CX188
family: BarraCuda 3.5 (SMR) size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5425 serial: <filter>
fw-rev: 0125 drive-rev: 0001 temp: 45 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 25231h+33m+25.482s
cycles: 105 read: 30.77 TiB written: 104.68 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-14: /dev/sdl maj-min: 8:176 vendor: SanDisk model: ST8000DM004-2CX188
fw-rev: 0125 drive-rev: 0001 temp: 47 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 22541h+42m+47.454s cycles: 82
read: 11.91 TiB written: 20.35 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-15: /dev/sdm maj-min: 8:192 vendor: SanDisk model: ST8000DM004-2CX188
SMART: yes state: enabled health: PASSED on: 41164h+52m+48.140s
cycles: 281 read: 39.88 TiB written: 58.84 TiB Pre-Fail:
ID-16: /dev/sdn maj-min: 8:208 vendor: SanDisk model: ST8000DM004-2CX188
fw-rev: 0125 drive-rev: 0001 temp: 46 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 32635h+49m+39.402s
cycles: 112 read: 41.25 TiB written: 52.83 TiB Pre-Fail:
ID-17: /dev/sdo maj-min: 8:224 vendor: Seagate model: ST4000DM000-1F2168
family: Desktop HDD.15 size: 3.64 TiB block-size: physical: 4096 B
sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5900 serial: <filter>
fw-rev: 0125 drive-rev: CC54 temp: 49 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 7y 169d 20h cycles: 10609
read: 223.47 TiB written: 48.58 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-18: /dev/sdp maj-min: 8:240 vendor: Western Digital
fw-rev: 0125 drive-rev: 85.00A85 temp: 58 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 296d 3h cycles: 48
ID-19: /dev/sdq maj-min: 65:0 vendor: Seagate model: ST10000NE0008-2PL103
family: IronWolf Pro size: 9.1 TiB block-size: physical: 4096 B
sata: 3.3 speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 0125 drive-rev: EN02 temp: 51 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 215d 8h cycles: 46
read: 51.68 TiB written: 63.99 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-20: /dev/sdr maj-min: 65:16 vendor: Seagate model: ST5000DM000-1FK178
family: Desktop HDD.15 size: 4.55 TiB block-size: physical: 4096 B
sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5980 serial: <filter>
fw-rev: 0125 drive-rev: CC49 temp: 49 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 7y 60d 8h cycles: 10405
read: 2.1 PiB written: 45.06 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-21: /dev/sds maj-min: 65:32 vendor: SanDisk model: ST8000DM004-2CX188
SMART: yes state: enabled health: PASSED on: 26908h+37m+53.557s
cycles: 148 read: 16.58 TiB written: 23.87 TiB Pre-Fail:
ID-22: /dev/sdt maj-min: 65:48 vendor: SanDisk model: ST8000DM004-2CX188
fw-rev: 0125 drive-rev: 0001 temp: 50 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 25856h+51m+06.569s
cycles: 138 read: 26.5 TiB written: 42.55 TiB Pre-Fail:
ID-23: /dev/sdu maj-min: 65:64 vendor: Toshiba model: MG07ACA14TE
family: MG07ACA... Enterprise Capacity HDD size: 12.73 TiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 sata: 3.3 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 0125 drive-rev: 0104 temp: 53 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 14d 8h cycles: 33
ID-24: /dev/sdv maj-min: 65:80 vendor: SanDisk model: ST8000DM004-2CX188
SMART: yes state: enabled health: PASSED on: 28737h+34m+02.553s
cycles: 153 read: 26.49 TiB written: 34.85 TiB Pre-Fail:
ID-25: /dev/sdw maj-min: 65:96 vendor: Western Digital
model: WD180EDGZ-11BLDS0 size: 16.37 TiB block-size: physical: 4096 B
sata: 3.5 speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1031 drive-rev: 85.00A85 temp: 48 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 68d 1h cycles: 677
ID-1: / raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
used: 541.28 GiB (60.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:4
used: 32.7 MiB (6.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:5
ID-3: /home raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
maj-min: 259:4
ID-4: /var/log raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
maj-min: 259:4
ID-5: /var/tmp raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
maj-min: 259:4
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:3
ID-2: swap-2 type: zram size: 31.25 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C mobo: 44.0 C gpu: amdgpu temp: 48.0 C
mem: 48.0 C
Memory: total: 32 GiB available: 31.25 GiB used: 3.27 GiB (10.5%)
Processes: 605 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: 2477 pm: pacman pkgs: 2473 libs: 617 tools: octopi,pamac,paru
pm: flatpak pkgs: 4 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-10-19
Last full system update: 2024-03-08 ↻
wc -c inxi.txt = 18124 bytes
I posted it in pastbin because of the size of 18Kb
I tried with openJDK 21, Minecraft 1.20.4 and 24w10a (the actual beta).
Minecraft startes now in Window-mode, switchen to Fullscreen-mode ingame has no problem now.
My Error was, as Minecraft started by default in fullscreen-mode and a few updates earlier…
