fiXed
28 April 2022 20:56
#1
Welcome,
I am new to the Linux world, but have encountered a problem that irritates me.
When playing Minecraft in single player mode, the game runs around 2000-5000 fps, but after entering the multiplayer server, the game does not exceed 100 fps.
Does anyone know why this is happening? Below I am inserting a link to a video that presents the problem in more detail.
Link to the video: Linux Garuda - problem (Minecraft multiplayer) - YouTube
That's a problem with the Minecraft server, ask the server admin for it.
Also, to be honest it's pointless to have Minecraft at more than 60 FPS.
fiXed
28 April 2022 21:10
#3
I doubt this is a server side problem because as I move away from the players the frames suddenly go up to around 500-1000fps.
In my opinion, it makes sense to play Minecraft at over 60 fps, because the gameplay is completely different than at lower fps.
fiXed:
5000
What hardware do you have? You missed the request for information contained in the topic template.
So - it's dependent on multiplayer aspects? Have you checked things like CPU use in this specific situation that could be bottlenecking your FPS?
How can you tell, given your monitor is refreshing at 60Hz?
fiXed
29 April 2022 05:37
#5
Oh, yeah, my mistake...
CPU: Intel Core i5-8400
GPU: GIGABYTE GTX 1060 3GB
RAM: 16 GB (2666 mHz)
Motherboard: ASUS B360-PLUS
During low frames in multiplayer, the CPU runs at 30-50%, which is normal.
As for the monitor, I have 144 Hz, not 60.
filo
29 April 2022 07:44
#6
Actually this means:
Post your terminal/konsole in- and output as text (no pictures ) from:
Personally, I still believe this is a server side problem, if the performance is good in single player.
Or maybe somewhere in the involved packages (much more unlikely).
But I really don't see it as a Garuda problem.
fiXed
29 April 2022 12:36
#7
Sorry, but I was not at the computer, that's why I wrote my specification in this way.
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3622471e-413b-4367-ab46-e0bfa86fc009 rw [email protected]
Type: Desktop Mobo: ASUSTeK model: PRIME B360-PLUS v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1101
date: 11/15/2018
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 3800 min/max: 800/4000 scaling: driver: intel_pstate
governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800
6: 3800 bogomips: 33599
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Gigabyte
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 84 s-size: 1162x327mm (45.75x12.87")
s-diag: 1207mm (47.52")
Monitor-1: DVI-D-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 119
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: N/A
Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 dpi: 92
size: 532x304mm (20.94x11.97") diag: 613mm (24.12") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:7 chip-ID: 0d8c:0005
Device-4: SteelSeries ApS Arctis 5 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:5 chip-ID: 1038:12aa
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.44 TiB used: 331.44 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: 1TB SSD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: T0709E0L
temp: 49.9 C scheme: GPT
model: WDS120G2G0B-00EPW0 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
used: 63.9 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 56 C
Processes: 285 Uptime: 31m wakeups: 0 Memory: 15.55 GiB
used: 3.86 GiB (24.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1793 lib: 520 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-04-27
Last full system update: 2022-04-28
McFly: Upgrading McFly DB to version 3, please wait...thread 'main' panicked at 'McFly error: Unable to add cm
d_tpl to commands (duplicate column name: cmd_tpl)', src/history/schema.rs:41:17
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
The first thing that comes to mind would be to try connecting to a few other servers besides that one, and see what kind of performance you observe.
fiXed
4 May 2022 09:38
#9
I have already tried to connect to different servers and still the same
filo
4 May 2022 10:34
#10
I see you have only an Ethernet card, no WiFi.
Have you tried replacing your network cable?
It would not be the first time I see randomly disconnecting Ethernet connections due to cabling issues. Maybe this could have an unnoticeable effect on general usability but bad side effects on Minecraft.
