Minecraft Font Problem 1.8
Hello, I have a problem with minecraft 1.8 fonts from minecraft launcher download using pacman and I have KDE Dr460nized Is the problem on my side that I have not downloaded something correct for it? I could provide an image later of whats showing
╰─λ sudo garuda-inxi
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=39f59fdb-1e36-436a-9194-a2fdf023749b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 4403 date: 04/27/2022
Info: model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3700 min/max: 2200/4950 boost: enabled
base/boost: 3700/4950 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 3700
13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 3700 20: 3700
21: 3700 22: 3700 23: 3700 24: 3700 bogomips: 177254
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 535.104.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 0b:00.0 chip-ID: 10de:2504
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 95 s-size: 1027x292mm (40.43x11.50")
s-diag: 1068mm (42.04")
Monitor-1: DP-1 pos: left res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0b:00.1 chip-ID: 10de:228e class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0c76:161e class-ID: 0300
Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.78 status: n/a (root, process) with:
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 4.59 TiB used: 19.36 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 147d 17h cycles: 1,040
read-units: 2,857,024,737 [1.46 PB] written-units: 2,648,276,237 [1.35 PB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
fw-rev: 111110WD temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 179d 19h cycles: 862
read-units: 2,882,807,138 [1.47 PB] written-units: 2,696,247,105 [1.38 PB]
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Toshiba model: KXG50ZNV1T02
NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: AADA4105
temp: 39.9 C scheme: GPT
SMART: yes health: PASSED on: 337d 23h cycles: 136
read-units: 16,717,471 [8.55 TB] written-units: 19,173,732 [9.81 TB]
ID-4: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAK1T0TDL-1AW1ZABHA
family: Micron Client SSDs size: 953.87 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 0032 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 205d 5h cycles: 106
read: 2.61 TiB written: 1.99 TiB Pre-Fail: attribute: Error_Correction_Count
ID-5: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100 family: 3.5"
DT01ACA... Desktop HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: A7C0 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 350d 9h cycles: 2275
used: 19.36 GiB (2.0%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 580 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.25 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 474 Uptime: 11m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 5.64 GiB (18.0%) Init: systemd v: 254
pm: pacman pkgs: 1971 libs: 560 tools: octopi,pamac,paru
inxi: 3.3.29
System install date:     2023-08-31
Last full system update: 2023-08-31 ↻
Windows dual boot:       Yes
╰─λ locale
LANG=en_CA.UTF-8
LC_CTYPE="en_CA.UTF-8"
LC_NUMERIC=en_CA.UTF-8
LC_TIME=en_CA.UTF-8
LC_COLLATE="en_CA.UTF-8"
LC_MONETARY=en_CA.UTF-8
LC_MESSAGES="en_CA.UTF-8"
LC_PAPER=en_CA.UTF-8
LC_NAME=en_CA.UTF-8
LC_ADDRESS=en_CA.UTF-8
LC_TELEPHONE=en_CA.UTF-8
LC_MEASUREMENT=en_CA.UTF-8
LC_IDENTIFICATION=en_CA.UTF-8
LC_ALL=
Just in case, although, most likely not related to your issue, this means a reboot is pending after the latest update.
Apart from that, I just saw this one on the Arch wiki.
https://wiki.archlinux.org/title/Minecraft#Broken_fonts_with_MinecraftForge
I’m not a gamer, but there are so many around here! Someone will help further…
gonna try the method and see if it's gonna work thanks you for sharing info
tried doing what the wiki told me to do same broken font
You could try using GDLauncher and see if it works.
Hi Anar I tried similar launcher to gdlauncher which is polymc i had the same problem with broken main menu with fonts
