Hello again!
Today I decided to install BlazingPack for Minecraft. When I try to start the game, the launcher throws me an error (screenshot). Does anyone know what's going on?
Regards, fiXed!
garuda-inxi:
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3622471e-413b-4367-ab46-e0bfa86fc009 rw [email protected]
Type: Desktop Mobo: ASUSTeK model: PRIME B360-PLUS v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1101
date: 11/15/2018
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 3800 min/max: 800/4000 scaling: driver: intel_pstate
governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800
6: 3800 bogomips: 33599
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Gigabyte
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 84 s-size: 1162x327mm (45.75x12.87")
s-diag: 1207mm (47.52")
Monitor-1: DVI-D-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 119
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: N/A
Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 dpi: 92
size: 532x304mm (20.94x11.97") diag: 613mm (24.12") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:6 chip-ID: 0d8c:0005
Device-4: SteelSeries ApS Arctis 5 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:5 chip-ID: 1038:12aa
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.38 TiB used: 397.36 GiB (16.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: 1TB SSD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: T0709E0L
temp: 51.9 C scheme: GPT
model: WDS120G2G0B-00EPW0 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
used: 156.92 GiB (16.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 25.3 MiB (8.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.54 GiB used: 228 MiB (1.4%)
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 328 Uptime: 1h 47m wakeups: 0 Memory: 15.55 GiB
used: 6.48 GiB (41.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1819 lib: 523 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-04-27
Last full system update: 2022-05-04 ↻
