Kernel: 5.17.11-hardened2-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 12.1.0 parameters: pti=on page_alloc.shuffle=1
BOOT_IMAGE=/@/.snapshots/133/snapshot/boot/vmlinuz-linux-hardened
root=UUID=244527e9-1a36-46bf-a50d-982f4ffa90b8 quiet quiet splash
rootflags=defaults,noatime,compress=zstd,discard=async,ssd,subvol=@/.snapshots/133/snapshot
Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: EECN36WW date: 05/17/2021
ID-1: BAT0 charge: 23.8 Wh (44.9%) condition: 53.0/52.5 Wh (100.9%)
volts: 11.3 min: 11.6 model: LGC L19L3PD6 type: Li-poly serial: <filter>
status: discharging cycles: 517
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1513 high: 1803 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1464 2: 1580
3: 1382 4: 1367 5: 1394 6: 1670 7: 1450 8: 1803 bogomips: 31948
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1636
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:3
chip-ID: 5986:212a class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1406 built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL:
renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.11-hardened2-1-hardened)
v: 4.6 Mesa 22.1.0 direct render: Yes
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_pci_acp6x, snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.11-hardened2-1-hardened running: yes
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
bus-ID: 3-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 141.08 GiB (29.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVME 512G size: 476.94 GiB
type: SSD serial: <filter> rev: T1102A0L temp: 35.9 C scheme: GPT
ID-1: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 16.8 MiB (5.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 212.07 GiB size: 212.07 GiB (100.00%)
used: 66.42 GiB (31.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /var/log raw-size: 212.07 GiB size: 212.07 GiB (100.00%)
ID-4: /var/tmp raw-size: 212.07 GiB size: 212.07 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.21 GiB used: 10 MiB (0.1%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 311 Uptime: 5m wakeups: 5 Memory: 7.21 GiB
used: 3.01 GiB (41.8%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1612 pacman: 1607 lib: 382 flatpak: 5
Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-31
Last full system update: 2022-05-30
problem is i mistakenly change microphone analog stereos output it remove suddenly i can't any setting to reset back to
