Hello Everybody. I hope you're doing ok.
I am a linux beginner and I don't know what is my problem. I have dual boot Windows 11 and Garuda. My mic works fine in Windows 11 but in garuda it doesn't work at all.
my laptop model is Lenovo Ideapad 330 15IKB - 81DE
help me if it is possible. I would really appreciate it.
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f82e1187-bfbe-4bf7-894f-f296689fa116 rw rootflags=subvol=@
resume=UUID=2c3153ae-e256-4d79-b13d-0da2ee1013a2 loglevel=3
Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-15IKB
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 8TCN53WW date: 05/17/2019
ID-1: BAT0 charge: 16.7 Wh (100.0%) condition: 16.7/30.0 Wh (55.7%)
volts: 8.4 min: 7.6 model: LGC L17L2PF1 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4000 scaling: driver: intel_pstate
8: 800 bogomips: 31999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
off: eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-3
code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie: gen: 1
speed: 2.5 GT/s lanes: 2 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6900 class-ID: 0380
Device-3: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:5
chip-ID: 5986:210f class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: MSI MP221
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-2: eDP-1 note: disabled model: BOE Display 0x07a3 built: 2017
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa
22.1.7 direct render: Yes
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Sound Server-2: PulseAudio v: 16.1 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
chip-ID: 8086:3166 class-ID: 0280
bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.78 TiB used: 13.06 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gloway model: STK960GS3-S7
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1.00 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LCM2
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 10.53 GiB (35.1%)
fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 612 KiB
(0.1%) fs: vfat dev: /dev/sda10 maj-min: 8:10
ID-3: /home raw-size: 33.81 GiB size: 33.81 GiB (100.00%) used: 1.26 GiB
(3.7%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-4: /opt raw-size: 33.81 GiB size: 33.81 GiB (100.00%) used: 1.27 GiB
(3.7%) fs: btrfs dev: /dev/sda9 maj-min: 8:9
ID-5: /var/log raw-size: 30 GiB size: 30 GiB (100.00%) used: 10.53 GiB
(35.1%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
ID-6: /var/tmp raw-size: 30 GiB size: 30 GiB (100.00%) used: 10.53 GiB
ID-1: swap-1 type: zram size: 11.6 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 44.0 C pch: 46.5 C mobo: N/A gpu: amdgpu
temp: 41.0 C
Processes: 288 Uptime: 4m wakeups: 1 Memory: 11.6 GiB used: 2.56 GiB
(22.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1235 lib: 340 Shell: fish v: 3.5.1
Garuda (2.6.7-1):
System install date: 2022-09-13
Last full system update: 2022-09-15
