Hello Garuda users.
I am experiencing some issues regarding my microphone. I am using an Acer Aspire ES 15 es1-572-36xh laptop.
here's what garuda-inxi says about my audio devices:
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
the main problem is that the OS doesn't pick anything up, all I hear whenever I listen to what it's picking up is a bunch of noise.
This noise I also hear on windows sometimes, I use the microphone of my headset, and normally when you plug in a headset a popup appears asking you what device you're using (Headphones, microphone, headset, etc...) and I'd normally have to select Headset for the mic to work and for there not to be any noise. However, this doesn't happen on Linux, there's no way I know of for me to select headphones and I'm stuck with random noise.
here is what "aplay --list-devices" shows:
List of PLAYBACK Hardware Devices
card 0: PCH [HDA Intel PCH], device 0: ALC233 Analog [ALC233 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
dmesg | grep -E 'snd|sof':
[ 0.348100] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.348101] software IO TLB: mapped [mem 0x0000000085808000-0x0000000089808000] (64MB)
[ 11.540168] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 13.015732] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC233: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 13.015752] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.015761] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 13.015768] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 13.015773] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 13.015777] snd_hda_codec_realtek hdaudioC0D0: Mic=0x1b
LSPCI:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
02:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev 10)
(Sorry for my bad english, english isn't my main language + it's 3:25 AM rn and I'm tired)
If you need anymore information you can ask me for it and I'll be happy to provide you with it.
Welcome
Complete, please.
Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=35a8c8d2-c476-40ab-be89-32028c7bc458 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.0 tk: Qt v: 5.15.4 info: latte-dock
Type: Laptop System: Acer product: Aspire ES1-572 v: V1.18
Mobo: Acer model: T-Rex_SK v: V1.18 serial: <superuser required>
UEFI: Insyde v: 1.18 date: 01/03/2019
ID-1: BAT1 charge: 41.3 Wh (100.0%) condition: 41.3/48.9 Wh (84.5%)
volts: 16.6 min: 15.2 model: LG 004B384234314341 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2000 high: 2001 min/max: 400/2000 scaling:
driver: intel_pstate governor: performance cores: 1: 2000 2: 2000 3: 2001
4: 2000 bogomips: 15999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 04f2:b47f class-ID: 0e02 serial: <filter>
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0675 built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 22.1.1
direct render: Yes
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:4 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 465.76 GiB used: 48.84 GiB (10.5%)
model: WD5000LPCX-21VHAT0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 156.52 GiB size: 156.52 GiB (100.00%)
used: 48.7 GiB (31.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 136.8 MiB (13.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 156.52 GiB size: 156.52 GiB (100.00%)
ID-4: /var/log raw-size: 156.52 GiB size: 156.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 156.52 GiB size: 156.52 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 212 Uptime: 4m wakeups: 1 Memory: 15.5 GiB
used: 2.45 GiB (15.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1909
lib: 522 Shell: fish v: 3.4.1 running-in: alacritty inxi: 3.3.18
Garuda (2.6.3-2):
System install date: 2022-06-08
Last full system update: 2022-06-19
Did you disable fastboot in BIOS/M$?
Sometimes M$ appropriates the PC hardware for itself, because there are no other operating systems that could also access it.
May need to be repeated after M$ updates.
If it is a 3.5mm jack and the port can also be used for audio, you have to announce to ALSA that you want to use the microphone. It is explained in the Arch Wiki here:
Correctly detect microphone plugged in a 4-pin 3.5mm (TRRS) jack
On some modern laptops you may have a combined 3.5mm headset jack, instead of two separated ones, which may not be correctly detected by default. To make ALSA correctly detect plug-in status on your 3.5mm jack, you can put the following line into your /etc/modprobe.d/alsa-base.conf
options snd_hda_intel index=0 model=*your_model_setting*
For a complete list of options to put in your_model_setting
, see HD-Audio Codec-Specific Models or its source located at /usr/lib/modules/$(uname -r)/build/Documentation/sound/hd-audio/models.rst
(provided by the linux-docs package). A common model is dell-headset-multi
, even if the hardware is not from Dell.
I just tried that, I tried out many of the models that applied to me and I got mixed results.
Some models allowed me to switch which microphone to use in the audio pop up menu at the top and gave me the option to use Headset Microphone and/or Microphone, but even when I have those options selected, no sounds seems to be picked up. Not even the noise that comes from the internat microphone, it's just silent. Maybe it's just me not choosing the right models toh
