Internal microphone not working on my Thinkpad T14 Gen3. I am unsure when it stopped working.
Test microphone option is unavailable in Audio settings.
The audio input meter does not move. Looks like it is fixed. See screenshot.
garuda-inxi output
clocksource: hpet available: acpi_pm
root=UUID=fe410e33-593e-494a-b139-2307dc8635a7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 21CF003VUS v: ThinkPad T14 Gen 3
Mobo: LENOVO model: 21CF003VUS v: SDK0T76530 WIN serial: <filter>
UEFI: LENOVO v: R23ET62W (1.32 ) date: 11/11/2022
ID-1: BAT0 charge: 29.1 Wh (82.2%) condition: 35.4/39.3 Wh (90.2%)
power: 10.7 W volts: 12.3 min: 11.6 model: Celxpert LNV-5B10W51862@�
type: Li-poly serial: <filter> status: discharging cycles: 50
Info: model: AMD Ryzen 5 PRO 6650U with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1021 high: 2142 min/max: 400/4583 base/boost: 2900/4550
scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
ext-clock: 100 MHz cores: 1: 1379 2: 1367 3: 1967 4: 400 5: 1635 6: 400
7: 400 8: 400 9: 2142 10: 400 11: 1366 12: 400 bogomips: 69471
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 45.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 5986:1177
Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x143c built: 2021
res: 1920x1200 hz: 60 dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4")
diag: 355mm (14") ratio: 16:10 modes: max: 1920x1200 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.6.1-zen1-1-zen) device-ID: 1002:1681 memory: 1000 MiB
unified: no
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
Local Storage: total: 953.87 GiB used: 393.82 GiB (41.3%)
model: MZVL21T0HCLR-00BL7 size: 953.87 GiB block-size: physical: 512 B
fw-rev: CL2QGXA7 temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 38 hrs cycles: 18,453
read-units: 4,808,351 [2.46 TB] written-units: 3,212,121 [1.64 TB]
ID-1: / raw-size: 152.59 GiB size: 152.59 GiB (100.00%)
used: 77.23 GiB (50.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 487 MiB size: 486 MiB (99.80%)
used: 6.4 MiB (1.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 480.66 GiB size: 472.04 GiB (98.21%)
used: 288.55 GiB (61.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-4: /var/log raw-size: 152.59 GiB size: 152.59 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 152.59 GiB size: 152.59 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: partition size: 32.43 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 30.13 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): fan-1: 2062
Processes: 398 Uptime: 5h 1m wakeups: 2 Memory: total: 32 GiB note: est.
available: 30.13 GiB used: 8.84 GiB (29.3%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1797 libs: 405 tools: octopi,pamac,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2022-12-11
Last full system update: 2023-11-29 ↻
Failed units: nmb.service shadow.service
