Microphone not working latest Gnome ISO
I have an XPS 17 and I normally take meetings via teams, however in the latest build (231029) I am unable to get Microphone to work. Only way to hold a meeting now is through a Bluetooth Headset. Anyway to troubleshoot this issue?
garuda-inxi please?
What kind of microphone? How is it connected? What have you tried to make it work?
 ╭─reggie@garudaG in ~ took 7ms
 ╰─λ garuda-inxi
    root=UUID=ad623bc2-60df-4d41-872c-0901cb552a02 rw rootflags=subvol=@
  Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
    v: 45.0.1 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Dell product: XPS 17 9710 v: N/A
  Mobo: Dell model: 00D5DG v: A00 serial: <superuser required> UEFI: Dell
    v: 1.22.0 date: 08/11/2023
  ID-1: BAT0 charge: 50.2 Wh (98.2%) condition: 51.1/95.1 Wh (53.7%)
    volts: 11.5 min: 11.4 model: BYD DELL F8CPG15 type: Li-poly serial: <filter>
  Info: model: 11th Gen Intel Core i9-11900H bits: 64 type: MT MCP
    microcode: 0x46
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1021 high: 1100 min/max: 800/4900:4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1077 2: 1100 3: 800
    4: 1100 5: 1064 6: 1100 7: 1100 8: 800 9: 984 10: 1100 11: 1100 12: 1044
    13: 1059 14: 1021 15: 1100 16: 800 bogomips: 79872
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-11:3
    chip-ID: 0c45:6a11 class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
    s-diag: 599mm (23.6")
  Monitor-1: eDP-1 model: Sharp 0x1517 built: 2021 res: 1920x1200 hz: 60
    dpi: 133 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
    ratio: 16:10 modes: 3840x2400
  API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (TGL GT1) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:9a60 surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 535.113.01
    device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
    chip-ID: 8086:43c8 class-ID: 0401
  Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0026
  Local Storage: total: 953.87 GiB used: 132.84 GiB (13.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 36310029 temp: 34.9 C
  ID-1: / raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
    used: 132.72 GiB (42.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 150 MiB size: 146 MiB (97.33%)
    used: 120.3 MiB (82.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
  ID-4: /var/log raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
  ID-5: /var/tmp raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
  ID-1: swap-1 type: partition size: 18.63 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-2: swap-2 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 50.0 C mobo: 32.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 464 Uptime: 1m wakeups: 3196 Memory: total: 32 GiB note: est.
  available: 31.08 GiB used: 5.26 GiB (16.9%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1631
  pm: pacman pkgs: 1573 libs: 456 tools: gnome-software,pamac,paru pm: flatpak
  pkgs: 58 Shell: Bash v: 5.2.15 running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-10-30
  Last full system update: 2023-11-01
 ╭─reggie@garudaG in ~ took 5s
 ╰─λ
actually seems to be working although the microphone volume is super low. Not sure how that would be adjusted.
