Microphone mute button LED always on
After install Garuda KDE dragonized edition, the mic button LED is always on when muted and off. Toggling does disable and enable mic, but LED doesn’t change.
does anyone know a solution or has fixed this?
garuda-inxi:
  Kernel: 6.10.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=248b1a22-6e08-4ed9-8367-350243f4ed57 rw rootflags=subvol=@
    quiet rd.luks.uuid=07d431d0-6687-4e7b-8e61-7413be06bfdf loglevel=3
  Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Laptop System: ASUSTeK product: Zenbook S 13 UX5304VA_UX5304VA v: 1.0
  Mobo: ASUSTeK model: UX5304VA v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: UX5304VA.305
    date: 11/20/2023
  ID-1: BAT0 charge: 57.9 Wh (100.0%) condition: 57.9/63.0 Wh (91.8%)
    volts: 8.7 min: 8.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: full cycles: 63
  Info: model: 13th Gen Intel Core i7-1355U bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x4121
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 424 high: 600 min/max: 400/5000:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 600 2: 400 3: 497 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 62668
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
    built: 2022+ ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:a7a1 class-ID: 0300
  Device-2: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:2 chip-ID: 3277:0051
  Monitor-1: eDP-1 model: Samsung 0x417b built: 2021 res: 2880x1800 dpi: 253
    gamma: 1.2 size: 289x186mm (11.38x7.32") diag: 344mm (13.5") ratio: 16:10
    modes: 2880x1800
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-U) driver: mesa intel v: 24.1.5-arch1.2
    device-ID: 8086:a7a1 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.5-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0401
  API: ALSA v: k6.10.4-zen2-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: not found
    rfk-block: hardware: no software: no address: see --recommends
  Local Storage: total: 953.87 GiB used: 22.27 GiB (2.3%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
    used: 22.27 GiB (11.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-07d431d0-6687-4e7b-8e61-7413be06bfdf
    used: 728 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-3: /home raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
  ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
  ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.24 GiB used: 0 KiB (0.0%) priority: 100
  Src: /sys System Temperatures: cpu: 48.0 C mobo: N/A
  Memory: total: 16 GiB note: est. available: 15.24 GiB used: 2.14 GiB (14.0%)
  Processes: 291 Power: uptime: 1h 8m states: freeze,mem,disk
    suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.08 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 256
  Packages: pm: pacman pkgs: 1164 libs: 383 tools: yay Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32 running-in: yakuake
    inxi: 3.3.35
  System install date:     2024-08-13
  Last full system update: 2024-08-13
grafik
grafik
No, works here.
You try with different headsets?
Did you click on the icon???
Same results. if I selected other microphone and disable and enable, the LED turns off but I have do the same in every boot
ok… With the audio the problem is the same.
I explain myself, on garuda boot, no sound/microphone activated.
I have activated manually, disable and enable and works well…
How it activate permanently on boot the sound/micro? DE → KDE Plasma
Solved it!
sudo pacman -S alsa-utils
sudo systemctl enable alsa-restore
sudo systemctl start alsa-restore
You should probably then mark this as the solution for other folk.
