Microfon einstellung
Servus,
i such schon ne weile eine möglichkeit das Microfon besser einzustellen da jedes geräusch aufgenommen wird. Habe versucht Nvidia Brodecast zu finden, nur leider ohne erfolg. Kann mir bitte wer weiterhelfen ?
```text
  Kernel: 6.14.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    root=UUID=df9121f8-2ab0-4c04-a230-7b4a7577328a rw rootflags=subvol=@ quiet loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0 wm: kwin_wayland vt: 1
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends LLC. v: F40g date: 03/11/2025
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check
    built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
    microcode: 0xA201030
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4650 min/max: 550/4654 boost: enabled scaling: driver: amd-pstate-epp
    governor: performance cores: 1: 4650 2: 4650 3: 4650 4: 4650 5: 4650 6: 4650 7: 4650 8: 4650
    9: 4650 10: 4650 11: 4650 12: 4650 bogomips: 88791
  Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] driver: nvidia v: 570.133.07
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of 2025-01;
    EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: none off: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 09:00.0
    chip-ID: 10de:1f06 class-ID: 0300
  Device-2: Nintendo USB Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 7-4:3 chip-ID: 057e:030a class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
    driver: X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
    gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-3 pos: right model: LG (GoldStar) E2350 built: 2009 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9
  Monitor-2: HDMI-A-1 pos: primary,left model: LG (GoldStar) TV serial: <filter> built: 2019 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 30 gamma: 1.2 size: 1600x900mm (62.99x35.43")
    diag: 1836mm (72.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: nouveau device: 2 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 memory: 7.81 GiB
    display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 9 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 2060
    SUPER driver: N/A device-ID: 10de:1f06 surfaces: xcb,xlib,wayland
    gpu: corectrl, nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.4
    chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech [G533 Wireless Headset Dongle] driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3:8 chip-ID: 046d:0a66
  Device-4: Ha
rman JBL Quantum Stream Talk driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: 0ecb:20af class-ID: 0300
  API: ALSA v: k6.14.1-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: AVM GmbH FRITZ WLAN N v2 [RT5572/rt2870.bin] driver: rt2800usb type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:4 chip-ID: 057c:8501 class-ID: 0000
  IF: wlp11s0f3u1 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-3.1:5 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
    hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
    pairing: no
  Local Storage: total: 5.58 TiB used: 1.44 TiB (25.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB size: 465.76 GiB
    fw-rev: 1B4QFXO7 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
    fw-rev: 2B4QFXO7 temp: 41.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: LITE-ON IT model: LCS-256M6S size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 201 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX001-1NS164 size: 1.82 TiB
    fw-rev: CC41 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
    fw-rev: CC47 scheme: MBR
  ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 120GB size: 111.79 GiB
    fw-rev: 1B6Q scheme: GPT
  ID-7: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 830 Series size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B1Q
  ID-8: /dev/sdf maj-min: 8:80 vendor: Western Digital model: WD10JMVW-11AJGS4 size: 931.48 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
    mode: 3.2 gen-1x1 tech: HDD rpm: 5400 serial: <filter> fw-rev: 1014 scheme: GPT
  ID-1: / raw-size: 116.75 GiB size: 116.75 GiB (100.00%) used: 81.31 GiB (69.6%) fs: btrfs
    dev: /dev/sdb1 maj-min: 8:17
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.9 MiB (27.0%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:2
  ID-3: /home raw-size: 116.75 GiB size: 116.75 GiB (100.00%) used: 81.31 GiB (69.6%) fs: btrfs
  ID-4: /var/log raw-size: 116.75 GiB size: 116.75 GiB (100.00%) used: 81.31 GiB (69.6%)
    fs: btrfs dev: /dev/sdb1 maj-min: 8:17
  ID-5: /var/tmp raw-size: 116.75 GiB size: 116.75 GiB (100.00%) used: 81.31 GiB (69.6%)
  ID-1: swap-1 type: zram size: 31.26 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 12 dev: /dev/zram0
  System Temperatures: cpu: 65.6 C mobo: 32.0 C
  Memory: total: 32 GiB available: 31.26 GiB used: 14.54 GiB (46.5%)
  Processes: 476 Power: uptime: 3h 34m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.44 GiB
  Packages: pm: pacman pkgs: 1876 libs: 546 tools: octopi,paru Compilers: clang: 19.1.7
    gcc: 14.2.1 Client: shell wrapper v: 5.2.37-release inxi: 3.3.37
  System install date:     2025-02-05
  Last full system update: 2025-04-18
Hab bisschen gegoogelt und das Projekt hier gefunden NoiseTorch. Das ist im Prinzip sowas wie eine Open-Source alternative zu Nvidia Broadcast bezüglich Mikrofonen, dazu gibt es auch ein gutes Video:
NoiseTorch erzeugt ein virtuelles Mikrofon mit Geräuschunterdrückung.
Bei 7:03 gibt es auch eine kurze Demonstration wie gut das funktioniert
Danke, mein englisch is einfach nur schlecht, habs eben über die konsole installiert
Funktionierts schon oder brauchst du noch unterstützung? :slight_smile:
installiert ist es, bist zufällig auf dem dc server ?
klick mich wild durch
Ne bin nicht auf dem Discord, du kannst ja aber über Audacity z.B. dein Mikrofon aufnehmen und überprüfen obs funktioniert
obs erkennt das mic , neben geräusche sind weg, danke
grmbl, ich bin zu leise im dc hab rumgefummelt, jetzt is das mic weg
