I’ve been using Garuda for a while now and I’m pretty happy with it overall, but there’s this stuttering every few seconds that freezes all monitors for about one second. I’ve already tried a few things like changing the kernel and upgrading the BIOS, but nothing changed.
Today I found these error messages when doing journalctl -b -p3 -e -f
. They start just after the PC finished booting and continue every few seconds until it shuts down.
Jan 06 23:20:15 draco libddcutil[239916]: i2c_check_businfo_connector() failed for bus 9
Jan 06 23:20:17 draco systemd[4283]: Failed to start Powerdevil.
Jan 06 23:20:20 draco libddcutil[241160]: i2c_check_businfo_connector() failed for bus 9
Jan 06 23:20:23 draco systemd[4283]: Failed to start Powerdevil.
Jan 06 23:20:26 draco libddcutil[241189]: i2c_check_businfo_connector() failed for bus 9
Jan 06 23:20:28 draco systemd[4283]: Failed to start Powerdevil.
Jan 06 23:20:31 draco libddcutil[241221]: i2c_check_businfo_connector() failed for bus 9
Jan 06 23:20:34 draco systemd[4283]: Failed to start Powerdevil.
Jan 06 23:20:37 draco libddcutil[241251]: i2c_check_businfo_connector() failed for bus 9
Jan 06 23:20:39 draco systemd[4283]: Failed to start Powerdevil.
Jan 06 23:20:42 draco libddcutil[242494]: i2c_check_businfo_connector() failed for bus 9
Jan 06 23:20:45 draco systemd[4283]: Failed to start Powerdevil.
I checked these errors against the freezing and it matches perfectly. Just after every freeze a new i2c_check_businfo_connector() failed for bus 9
error shows up. I’m not sure if the other error is connected to the freezes, but it doesn’t seem so.
Of course I tried looking up this error, but I didn’t find anything useful, here or on Google. Is there any way for me to fix this problem?
Kernel: 6.1.70-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
root=UUID=8a635b38-79b3-418b-914f-15d084f0d99c rw rootflags=subvol=@ quiet quiet
resume=UUID=b9b675f9-5204-45ce-ac23-53e1467b7322 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Mobo: ASUSTeK model: ROG MAXIMUS XI CODE v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 1802 date: 12/01/2020
Device-1: ps-controller-battery-48:18:8d:42:e1:f1 model: N/A serial: N/A charge: N/A
status: charging
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xD (13)
microcode: 0xFA
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4700 high: 4701 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 4700 2: 4700 3: 4700 4: 4700 5: 4700 6: 4701 7: 4700 8: 4700
9: 4700 10: 4700 11: 4700 12: 4700 13: 4700 14: 4700 15: 4700 16: 4700 bogomips: 115232
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:3e98 class-ID: 0300
Device-2: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: ASUSTeK driver: nvidia v: 545.29.06
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: none off: DP-1, DP-2, HDMI-A-2, HDMI-A-3 empty: Unknown-1
bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
Device-3: Logitech BRIO 4K Stream Edition driver: snd-usb-audio,uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 046d:086b class-ID: 0102
Device-4: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2 speed: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 bus-ID: 2-3.1:4 chip-ID: 28de:2400 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 8120x2580 s-dpi: 96 s-size: 2148x682mm (84.57x26.85")
s-diag: 2254mm (88.73")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Nvidia built: 1990 size-res: N/A gamma: 1.2
modes: 640x480
Monitor-2: DP-2 note: disabled pos: primary,bottom-c model: Samsung LC49G95T serial: <filter>
built: 2020 res: 5120x1440 dpi: 130048 gamma: 1.2 size: 1x1mm (0.04x0.04") diag: 1239mm (48.8")
modes: max: 2560x1440 min: 640x480
Monitor-3: HDMI-A-1 mapped: HDMI-0 pos: middle-l model: Acer GN246HL serial: <filter>
built: 2016 res: 1080x1920 hz: 60 dpi: 92 gamma: 1.2 size: 299x531mm (11.77x20.91")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-4: HDMI-A-2 mapped: HDMI-1 note: disabled pos: top-center model: VG245 serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 size: 595x336mm (23.43x13.23")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-5: HDMI-A-3 mapped: HDMI-1-1 note: disabled pos: bottom-r model: Acer Z271
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 683mm (26.9") ratio: 16:9 modes: max: 1920x1080
min: 640x480
API: EGL v: 1.5 hw:
drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: iris device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 memory: 10.74 GiB
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: integrated-gpu name: Intel UHD Graphics 630
(CFL GT2) driver: mesa intel v: 23.3.2-arch1.2 device-ID: 8086:3e98 surfaces: xcb,xlib
device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 2080 Ti driver: nvidia v: 545.29.06
device-ID: 10de:1e07 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: YUAN High-Tech Development vendor: Corsair Memory driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 2 link-max: lanes: 4 bus-ID: 02:00.0 chip-ID: 12ab:0710 class-ID: 0480
Device-4: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3.3.2:9 chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-5: Valve VR Radio & HMD Mic driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3.3:12 chip-ID: 28de:2102 class-ID: 0102
Device-6: Logitech BRIO 4K Stream Edition driver: snd-usb-audio,uvcvideo type: USB rev: 2.1
Device-7: Sony DualSense wireless controller (PS5) driver: playstation,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:6 chip-ID: 054c:0ce6
Device-8: SteelSeries ApS Arctis Pro Wireless driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.3.3:23 chip-ID: 1038:1294
API: ALSA v: k6.1.70-1-lts status: kernel-api tools: alsactl,alsamixer,amixer
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Sony DualSense wireless controller (PS5) driver: playstation,snd-usb-audio,usbhid
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:21 chip-ID: 8087:0aaa class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1 lmp-v: 10 status:
discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 6.37 TiB used: 544.65 GiB (8.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
block-size: physical: 512 B logical:
512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 5B2QGXA7 temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
fw-rev: 2B2QEXE7 temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5980 serial: <filter>
fw-rev: SC60 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: ASUS model: Tek ROG RYUJIN size: 4 MiB block-size:
physical: 4096 B logical: 4096 B type: USB rev: 2.0 spd: 12 Mb/s lanes: 1 mode: 1.1 tech: N/A
serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 544.65 GiB (29.8%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 588 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 544.65 GiB (29.8%) fs: btrfs
ID-4: /var/log raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 544.65 GiB (29.8%) fs: btrfs
ID-5: /var/tmp raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 544.65 GiB (29.8%) fs: btrfs
ID-1: swap-1 type: partition size: 34.31 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 34%
Processes: 452 Uptime: 45m wakeups: 0 Memory: total: 32 GiB available: 31.19 GiB
used: 9.08 GiB (29.1%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman pkgs: 1627 libs: 492 tools: octopi,paru
Client: shell wrapper v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-09-01
Last full system update: 2024-01-03
