I don't really know where this issue stems from, but the mic icon in the top bar, when muted, is actually unmuted. When it says it's unmuted, it's actually muted. Is this an issue for anyone else? It seems to happen across multiple different applications using the microphone.
I searched for the forum for similar issues but can't seem to find any posts about similar issues.
root=UUID=11374ffd-57dd-4850-ae21-7018ba2a4020 rw rootflags=subvol=@
quiet
cryptdevice=UUID=a3b5cba1-2dfa-428f-8997-3864dc0e7ca3:luks-a3b5cba1-2dfa-428f-8997-3864dc0e7ca3
root=/dev/mapper/luks-a3b5cba1-2dfa-428f-8997-3864dc0e7ca3 quiet splash
ipv6.disable=1 ipv6.disable=0
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: Maximus IV Extreme v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 3604
date: 04/12/2013
Info: model: Intel Core i7-2600K bits: 64 type: MT MCP arch: Sandy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2551 high: 3425 min/max: 1600/5900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1688 2: 2878 3: 2097
4: 2086 5: 2998 6: 3425 7: 2966 8: 2273 bogomips: 54579
vulnerable
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13c0 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Screen-1: 0 s-res: 3840x1080 s-dpi: 85 s-size: 1147x319mm (45.16x12.56")
s-diag: 1191mm (46.87")
Monitor-1: DVI-I-0 pos: right res: 1280x1024 hz: 60 dpi: 86
size: 376x301mm (14.8x11.85") diag: 482mm (18.96") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1080 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 1-1.4.1:8
bus-ID: 00:1b.0 chip-ID: 1038:12ad class-ID: 0300 chip-ID: 8086:1c20
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 type: USB
Device-4: Shure X2u Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.6:7 chip-ID: 14ed:29b6
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
Device-2: Intel 82583V Gigabit Network vendor: ASUSTeK driver: e1000e
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: b000 bus-ID: 0c:00.0
chip-ID: 8086:150c class-ID: 0200
IF: enp12s0 state: down mac: <filter>
Device-3: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 2-1.6:4 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u6 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 0a12:0001 class-ID: fe01
address: <filter>
Local Storage: total: 447.13 GiB used: 42.45 GiB (9.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP480G4
type: SSD serial: <filter> rev: 0420 scheme: MBR
ID-1: / raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.45 GiB
(9.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a3b5cba1-2dfa-428f-8997-3864dc0e7ca3
ID-2: /home raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.45
GiB (9.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-3: /var/log raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.45
ID-4: /var/tmp raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.45
ID-1: swap-1 type: zram size: 31.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 74 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 44%
Processes: 331 Uptime: 18h 35m wakeups: 51 Memory: 31.32 GiB used: 7.66 GiB
(24.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1276 libs: 332
Garuda (2.6.9-1):
System install date: 2022-10-21
Last full system update: 2022-10-24 ↻
I forgot to mention, it's actually displaying two separate mic icons instead of one. Both have identical status.
