I’m still trying to learn where to find information, so I don’t know where to look yet.
Just curious about MESA 25 release, when will it show up when doing a garuda-update?
Ask the developer
please.
Thanks, was not sure where to get info.
Welp, I am unable to create an account, to post a question asking. Anyone have a current account to pose the question to the developer? Thanks.
I just noticed this was moved from communmity to issues & assistance. Here is the inxi.
Kernel: 6.13.4-arch1-1-znver4 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver4
root=UUID=5db8ceb0-64fe-409a-8b0c-4adcb5f8a260 rw rootflags=subvol=@
quiet loglevel=3 amdgpu.ppfeaturemask=0xffffffff ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop Mobo: Gigabyte model: B650M AORUS ELITE AX v: x.x
Megatrends LLC. v: FA3a date: 02/06/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4531 min/max: 400/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4531 2: 4531 3: 4531
4: 4531 5: 4531 6: 4531 7: 4531 8: 4531 9: 4531 10: 4531 11: 4531 12: 4531
13: 4531 14: 4531 15: 4531 16: 4531 bogomips: 134148
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Tul / PowerColor driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2 bus-ID: 12:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 32.0 C
gpu: amdgpu d-rect: 5360x1440 display-ID: 0
Monitor-1: DP-3 pos: primary,left model: LG (GoldStar) 34GN850
serial: <filter> built: 2020 res: mode: 3440x1440 hz: 160 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19") diag: 867mm (34.1")
modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 pos: right model: HP 25bw serial: <filter> built: 2014
res: mode: 1920x1080 hz: 60 scale: 178% (1.78) to: 1080x1920 dpi: 88
gamma: 1.2 size: 553x311mm (21.77x12.24") diag: 634mm (25") ratio: 16:9
navi31 LLVM 19.1.7 DRM 3.60 6.13.4-arch1-1-znver4) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.4-arch1-1-znver4 status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
port: d000 bus-ID: 09:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0bda:0852
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 1.82 TiB used: 43.35 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHPP41-2000GM size: 1.82 TiB block-size: physical: 512 B
fw-rev: 51060A20 temp: 50.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 43.34 GiB (2.3%)
used: 43.34 GiB (2.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.9 C mobo: 35.0 C
GPU: device: amdgpu temp: 59.0 C mem: 70.0 C fan: 0 watts: 43.00
device: amdgpu temp: 32.0 C
Memory: total: 32 GiB note: est. available: 30.49 GiB used: 3.98 GiB (13.1%)
Processes: 417 Power: uptime: 2h 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.19 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1662 libs: 533 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-02-06
Last full system update: 2025-02-26 ↻
I see it’s time to get abit nervous
What kind of answer would you expect? What would come is, it’s ready when it’s ready.
Forgive me for asking for an ETA, it did not realize it was forbidden to do so.
Nobody said anything about a ban.
But the developers will finish faster if they are not constantly asked about the delivery date.
