Greetings,
I am sivarajan, I am new to Garuda Linux and Latte Dock .I found that application Menu is on top panel instead of in the application. I would like my applications(in this case I put konsole) to look like the below with menu bar.
instead of looking like this:
Oh you mean all applications, I thought you meant Konsole only.
You need to find it in Latte dock settings, rightclick Latte and go for its settins (not the panel settings) and disable removing the menu bar from there. Then rightclick the upper Latte panel and remove the window buttons / appmenu Plasmoids which provide both in default configuration.
Do the change using Latte preferences (disable Use borderless maximized windows setting and logout/login to have effect.
You should clear $HOME/.cache/* before logout.
