Hi all,
when running Garuda-Update or when trying to use Pamac, the application is rapidly consuming all available ram on my device (64GB) and then crashing my desktop. I’m unable to apply updates and I’m unsure of what I should do or how to even begin troubleshooting this.
─async@async in ~ took 6ms
╰─λ garuda-inxi
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b1f8081c-85dc-40ac-836d-7fea9f7438eb rw rootflags=subvol=@
quiet resume=UUID=78e7bacb-5662-4b65-8412-de28ea472132 loglevel=3 ibt=off
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Garuda
Type: Desktop Mobo: System76 model: Thelio Mira v: thelio-mira-r2
UEFI: American Megatrends v: 4403 date: 04/27/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3689 high: 3836 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3633 10: 3700 11: 3593
12: 3700 13: 3592 14: 3700 15: 3700 16: 3700 17: 3700 18: 3836 19: 3592
20: 3700 21: 3700 22: 3700 23: 3700 24: 3700 bogomips: 177268
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: PNY
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 0b:00.0 chip-ID: 10de:2216 class-ID: 0300
Device-2: SunplusIT Depstech webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
chip-ID: 1bdf:5060 class-ID: 0102 serial: <filter>
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 92 s-size: 1060x596mm (41.73x23.46")
s-diag: 1216mm (47.88")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: LG (GoldStar)
ULTRAGEAR+ serial: <filter> built: 2022 res: 3840x2160 hz: 60 dpi: 93
gamma: 1.2 size: 1050x590mm (41.34x23.23") diag: 1204mm (47.4")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: Vulkan v: 1.3.276 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 545.29.06
device-ID: 10de:2216 surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio vendor: PNY
bus-ID: 0b:00.1 chip-ID: 10de:1aef class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: XMOS X1S USB DAC driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 20b1:3023 class-ID: 0300
Device-4: Razer USA Seiren Mini driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 1532:0531 class-ID: 0300 serial: <filter>
Device-5: SunplusIT Depstech webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0608
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0e8d:0608
Local Storage: total: 2.39 TiB used: 78.13 GiB (3.2%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXG7 temp: 37.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 37.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Lexar model: USB Flash Drive
size: 119.24 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 78.13 GiB (4.3%)
used: 78.13 GiB (4.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.25 GiB used: 4 MiB (0.0%) priority: 100
System Temperatures: cpu: 57.4 C mobo: 38.0 C gpu: nvidia temp: 44 C
Memory: total: 32 GiB available: 31.25 GiB used: 8.18 GiB (26.2%)
Processes: 472 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: gsd-power,
Packages: pm: pacman pkgs: 1508 libs: 513 tools: pamac,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-30
Last full system update: 2024-02-19
