Hello, long story short in the bios my ram is set to default 2600hz i have 4000hz ram and when i changed it to D.O.C.P and set it to 4000hz Garuida wont boot.
I am likely missing something very basic as i have had no issues on windows running 4000hz.
Please let me know your thoughts
Thanks in advance
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=bb0545a2-6262-4460-8bc5-99f6c3414ad1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x
serial: part-nu: SKU uuid:
UEFI: American Megatrends v: 4602 date: 02/23/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3686 high: 3700 min/max: 2200/5073 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3593 5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700
12: 3585 13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 3700
20: 3588 21: 3700 22: 3700 23: 3700 24: 3700 bogomips: 177261
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1,Writeback-1
bus-ID: 0b:00.0 chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-3 pos: primary,left res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.9.3-zen1-1-zen) device-ID: 1002:73bf
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.2
Local Storage: total: 4.19 TiB used: 34.01 GiB (0.8%)
model: MZVLB512HBJQ-00A00 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: EXF7201Q temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 size: 1.86 TiB
serial: fw-rev: 7A scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 1.86 TiB
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 34.01 GiB (1.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 588 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 34.01 GiB (1.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.5 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 44.0 C
Memory: total: 64 GiB note: est. available: 62.7 GiB used: 4.32 GiB (6.9%)
Processes: 476 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1952 libs: 579 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-06-09
Last full system update: 2024-06-10
