Meld in Rani
╰─ λ # ><°> garuda-inxi
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=1f858aa4-dc21-4849-9613-fd93f2269a29 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop System: Gigabyte product: A520M S2H v: -CF
Mobo: Gigabyte model: A520M S2H v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F19d
date: 09/02/2024
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 5 5600GT with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2391 min/max: 422/4669 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2391 2: 2391 3: 2391
4: 2391 5: 2391 6: 2391 7: 2391 8: 2391 9: 2391 10: 2391 11: 2391 12: 2391
bogomips: 86238
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 29.0 C
Monitor-1: HDMI-A-1 model: Dell P2210 serial: <filter> built: 2011 res:
mode: 1680x1050 hz: 60 scale: 100% (1) dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.2
renoir ACO DRM 3.63 6.15.4-zen2-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.4.313 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.1.4-arch1.2
device-ID: 1002:1638 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.6 256 bits) driver: mesa llvmpipe v: 25.1.4-arch1.2 (LLVM
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 931.51 GiB used: 654.46 GiB (70.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: CBG04418 temp: 26.9 C
used: 654.46 GiB (70.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 14.99 GiB used: 12.8 MiB (0.1%)
System Temperatures: cpu: 36.6 C mobo: 29.0 C gpu: amdgpu temp: 30.0 C
Memory: total: 16 GiB note: est. available: 14.99 GiB used: 3.28 GiB (21.9%)
Processes: 338 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.97 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2565 libs: 603 tools: octopi,
pacaur, pacseek, paru, pikaur, trizen, yay Compilers: clang: 20.1.7
gcc: 15.1.1 alt: 13/14 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2025-03-21
Last full system update: 2025-07-03
… nach dem Update heute hatte ich in Rani wieder Meldung (pacdiff), wenn ich in Rani dann Start Merging drücke öffnet sich Meld aber nicht ???
Had the same problem, Garuda Rani doesn’t seem to launch Meld, so I just launched it manually and compared the files that way.
Einfach meld
sudo pacman -S meld
installieren.
Weil es nicht alle DE’s von Garuda’s Anbeginn, und speziell KDE, vorinstalliert haben.
Und bitte @Terrorizer :smiley:
  • Formatieren Sie alle Terminaltexte (einschließlich garuda-inxi) als Code-Block, indem Sie auf die Schaltfläche für vorformatierten Text, </>, klicken, oder setzen Sie drei Tilde (~) über und unter den Text.
bearbeite dein garuda-inxi .
Same thing happened to me
Yeah it doesn’t start for me via rani anymore, have to do pacdiff in Konsole
Aaaah this is too funny. I’ve tested this as working when pushing the last commits. :frowning:
Here I replaced the logic with a script in garuda-lib (it was indeed broken before that).
You guys are all running the latest version of Rani and garuda-libs?
Someone do me a favor and test whether running bash /usr/lib/garuda/pacdiff-merge works as expected please.
Latest as non git version?
bash: /usr/lib/garuda/pacdiff-merge: No such file or directory
Well that explains everything :sweat_smile: let me look into this. And yes, 3.0.2.
Okay, yeah, that is the version I have. Time to call the exorcist.
Aaaaaaaaaaaaaah. It hurts seeing it, I accidentally placed it in the wrong place. My bad, I’ll fix this asap.
To verify, run bash /usr/bin/pacdiff-merge, this should work as expected.
Edit: should be fixed once you guys updated.
