Meld -> Help error
First time using meld on both Dragonized (desktop) & Mokka (laptop). When I selected ‘Help’ in the GUI, this message showed up in the terminal window on both computers:
Created snapshot 25
Merging /etc/pacman.d/mirrorlist.pacnew ...
File "/usr/lib/python3.13/site-packages/meld/meldapp.py", line 128, in help_callback
Gtk.show_uri(
Gdk.Screen.get_default(), uri, Gtk.get_current_event_time())
gi.repository.GLib.GError: g-io-error-quark: The specified location is not supported (15)
This happend on todays (3/30/25) update. Parliamentry procedures ensue:
Kernel: 6.14.0-arch1-1-znver5 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver5
root=UUID=1e687301-70d2-4461-b24f-ad53850a97e4 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: MPG X870E CARBON WIFI (MS-7E49) v: 1.0
Megatrends LLC. v: 1.A30 date: 03/12/2025
Info: model: AMD Ryzen 9 9950X bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404023
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3632 min/max: 600/5756 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3632 2: 3632 3: 3632
4: 3632 5: 3632 6: 3632 7: 3632 8: 3632 9: 3632 10: 3632 11: 3632 12: 3632
13: 3632 14: 3632 15: 3632 16: 3632 17: 3632 18: 3632 19: 3632 20: 3632
21: 3632 22: 3632 23: 3632 24: 3632 25: 3632 26: 3632 27: 3632 28: 3632
29: 3632 30: 3632 31: 3632 32: 3632 bogomips: 275199
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire NITRO+ driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3,
Writeback-2 bus-ID: 7a:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 44.0 C
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: MSI MPG271QX OLED built: 2024 res: mode: 2560x1440
hz: 120 scale: 110% (1.1) to: 2327x1309 dpi: 107 gamma: 1.2
size: 606x344mm (23.86x13.54") diag: 697mm (27.4") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
navi31 LLVM 19.1.7 DRM 3.61 6.14.0-arch1-1-znver5) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:13c0
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 7a:00.1 chip-ID: 1002:1640
speed: 16 GT/s lanes: 16 bus-ID: 7a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:6
chip-ID: 0db0:0b58 class-ID: 0300
API: ALSA v: k6.14.0-arch1-1-znver5 status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: c000 bus-ID: 09:00.0
chip-ID: 10ec:8126 class-ID: 0200
Device-3: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 2 bus-ID: 10:00.0
chip-ID: 17cb:1107 class-ID: 0280
IF: wlp16s0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:5 chip-ID: 0489:e10a
Local Storage: total: 1.82 TiB used: 18.11 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T705SSD3
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5111 temp: 41.9 C
ID-1: / raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
used: 18.11 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-4: /var/log raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 60.37 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 47.8 C mobo: 35.5 C
Fan Speeds (rpm): fan-1: 0 fan-2: 2948 fan-3: 0 fan-4: 0 fan-12: 982
fan-13: 0 fan-14: 0 fan-15: 0 fan-16: 0
GPU: device: amdgpu temp: 49.0 C device: amdgpu temp: 60.0 C mem: 68.0 C
fan: 0 watts: 40.00
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.12
Memory: total: 60 GiB note: est. available: 60.37 GiB used: 4.26 GiB (7.1%)
Processes: 606 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1470 libs: 407 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date:     2025-03-27
Last full system update: 2025-03-30
This is a bug in meld, Garuda cannot fix it and it has nothing to do with the update.
Edit: The broken help button in meld only triggers the online help.
Workaround: call up the online help manually via Meld Help. :slight_smile:
