Megasync is not lauching in Garuda Hyprland
Hello Garuda users.
i’m new to linux window manager
when i lauch megasync that what i get :
 megasync
Avoiding wayland
Error unsetting QT_QPA_PLATFORMTHEME vble
  Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=275451d6-6f5f-4ce5-831d-ff804642e173 rw rootflags=subvol=@
  Type: Laptop System: HP product: HP EliteBook 840 G4 v: N/A
  Mobo: HP model: 828C v: KBC Version 45.52 serial: <superuser required>
    UEFI: HP v: P78 Ver. 01.45 date: 12/15/2022
  ID-1: BAT0 charge: 17.9 Wh (41.9%) condition: 42.7/51.3 Wh (83.3%)
    volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: charging cycles: 718
  Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF4
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 800 min/max: 400/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 21599
  Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
  Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-9:3 chip-ID: 05c8:0397 class-ID: 0e02 serial: <filter>
    compositor: Hyprland driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: AU Optronics 0x123d built: 2013 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 scale: 1 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
  API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 620 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:5916 surfaces: xcb,xlib,wayland device: 1 type: cpu
  API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
  Local Storage: total: 238.47 GiB used: 21.73 GiB (9.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAV256TBN-1AR15ABHA
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0T12 scheme: GPT
  ID-1: / raw-size: 20 GiB size: 20 GiB (100.00%) used: 5.86 GiB (29.3%)
    fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
    used: 576 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5
  ID-3: /home raw-size: 29.61 GiB size: 29.61 GiB (100.00%)
    used: 92.1 MiB (0.3%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
  ID-4: /var/log raw-size: 20 GiB size: 20 GiB (100.00%)
    used: 5.86 GiB (29.3%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-5: /var/tmp raw-size: 20 GiB size: 20 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 51.0 C pch: 39.0 C mobo: N/A
  Processes: 241 Uptime: 1h 13m wakeups: 7 Memory: total: 8 GiB
  available: 7.64 GiB used: 2 GiB (26.2%) Init: systemd v: 254
  pm: pacman pkgs: 1203 libs: 357 tools: paru Shell: fish v: 3.6.1
  running-in: foot inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-10-15
  Last full system update: 2023-10-15 ↻
It appears to be a known issue.
