I have looked all over for a fix to this and cant seem to fix it. when i was runing windows on this hardware i was getting the full 1GB speed i usaly do but in linux its all the way down to just 100mbs sometimes even less and im still new to this distro so im not 100% on everything but ive done as much as i can on my own and would love some help to fix this
here is some outputs that might help! if you need more just ask, again I am new to all this! <3
lsmod | sort
Device-1: Intel Ethernet I226-V driver: igc
IF: eno1 state: down mac: e8:9c:25:a8:2f:78
Device-2: MEDIATEK driver: mt7925e
IF: wlp7s0 state: up mac: c0:bf:be:45:b4:6c
Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4076ab94-73b0-40e1-8701-24fcc928a03e rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG STRIX B850-A GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1001 date: 01/11/2025
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404023
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2983 min/max: 600/5269 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 2983 2: 2983 3: 2983
4: 2983 5: 2983 6: 2983 7: 2983 8: 2983 9: 2983 10: 2983 11: 2983 12: 2983
13: 2983 14: 2983 15: 2983 16: 2983 bogomips: 150399
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
v: 570.86.16 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2487 class-ID: 0300
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-3,HDMI-A-3,Writeback-1
bus-ID: 0c:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 39.0 C
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:9
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
gpu: nvidia,nvidia-nvswitch d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-2 pos: primary,top-left model: Dell AW3423DWF
serial: <filter> built: 2023 res: mode: 3440x1440 hz: 165 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 800x337mm (31.5x13.27") diag: 868mm (34.2")
modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-2 pos: bottom-r model: Dell SE2717H/HX serial: <filter>
built: 2017 res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: radeonsi gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 570.86.16
API: Vulkan v: 1.4.303 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2487
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:13c0
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:1640
Device-3: FiiO K7 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 2972:0047 class-ID: fe01
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 0b05:1b9b class-ID: 0300
Device-5: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.1.1.4:17
chip-ID: 03f0:0d8b class-ID: 0300 serial: <filter>
Device-6: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:125c
Device-2: MEDIATEK vendor: AzureWave driver: mt7925e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 14c3:7925
IF: wlp7s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
chip-ID: 13d3:3602 class-ID: e001 serial: <filter>
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.4 lmp-v: 13
Local Storage: total: 4.57 TiB used: 2.99 TiB (65.4%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 953.87 GiB block-size: physical: 512 B
fw-rev: VB421D65 temp: 35.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:7 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 44.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 78.13 GiB size: 78.13 GiB (100.00%)
used: 25.32 GiB (32.4%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 40.8 MiB (42.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 78.13 GiB size: 78.13 GiB (100.00%)
ID-4: /var/log raw-size: 78.13 GiB size: 78.13 GiB (100.00%)
ID-5: /var/tmp raw-size: 78.13 GiB size: 78.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.4 C mobo: 36.5 C gpu: amdgpu temp: 39.0 C
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 6.8 GiB (22.3%)
Processes: 419 Power: uptime: 1h 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1503 libs: 459
tools: gnome-software,octopi,paru Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-01-28
Last full system update: 2025-02-10 ↻
