I don’t have an internal bluetooth adapter on this motherboard, hence the use of the adapter.
Kernel: 6.13.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
root=UUID=81917e19-1ef7-4f5d-adb2-efa1f1cc34fe rw rootflags=subvol=@ quiet quiet
resume=UUID=b5f5224c-7f0c-4f99-b519-7c88d92f1a1a loglevel=3 acpi_enforce_resources=lax splash
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0 wm: kwin_wayland
with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE V2 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FGd date: 09/02/2024
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 2
microcode: 0xA201210
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4441 min/max: 550/4550 boost: enabled scaling: driver: amd-pstate-epp
governor: performance cores: 1: 4441 2: 4441 3: 4441 4: 4441 5: 4441 6: 4441 7: 4441 8: 4441
9: 4441 10: 4441 11: 4441 12: 4441 13: 4441 14: 4441 15: 4441 16: 4441 bogomips: 108593
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Speedster MERC 319 driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
off: HDMI-A-1 empty: DP-1,DP-3,Writeback-1 bus-ID: 09:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: Huawei HiCamera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-2.2.1:5 chip-ID: 12d1:4321 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Dell AW3423DWF serial: <filter> built: 2022 res: mode: 3440x1440 hz: 165
scale: 100% (1) dpi: 109 gamma: 1.2 size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes:
max: 3440x1440 min: 720x400
Monitor-2: HDMI-A-1 model: HDMI2K built: 2017 res: 1920x1080 dpi: 79 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 707mm (27.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi navi21 LLVM 19.1.7 DRM 3.59
6.13.2-zen1-1-zen) device-ID: 1002:73bf memory: 15.62 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.304 layers: 11 device: 0 type: discrete-gpu name: AMD Radeon RX 6900 XT
(RADV NAVI21) driver: N/A device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
gpu: corectrl, lact, radeontop wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-3:
C-Media USB Audio Device driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 0d8c:0012 class-ID: 0300
Device-4: Huawei HiCamera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
API: ALSA v: k6.13.2-zen1-1-zen status: kernel-api tools: alsactl,alsamixer,amixer
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-6.3:4 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
Local Storage: total: 1.83 TiB used: 1.03 TiB (56.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G size: 465.76 GiB
fw-rev: ELFK0S.6 temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT1000P3SSD8 size: 931.51 GiB
fw-rev: P9CR30A temp: 48.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB
fw-rev: 6B0Q
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT256MX100SSD1 size: 238.47 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: MU02
ID-1: / raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 152.53 GiB (35.4%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 248.3 MiB (82.9%) fs: vfat
ID-3: /home raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 152.53 GiB (35.4%) fs: btrfs
ID-4: /var/log raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 152.53 GiB (35.4%)
ID-5: /var/tmp raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 152.53 GiB (35.4%)
ID-1: swap-1 type: zram size: 31.26 GiB used: 180 MiB (0.6%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 16 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.39 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 55.1 C mobo: 22.0 C gpu: amdgpu temp: 34.0 C mem: 32.0 C
Memory: total: 32 GiB available: 31.26 GiB used: 6.67 GiB (21.3%)
Processes: 556 Power: uptime: 4m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.48 GiB
Packages: pm: pacman pkgs: 1608 libs: 416 tools: paru Comp
ilers: clang: 19.1.7 gcc: 14.2.1
Client: shell wrapper v: 5.2.37-release inxi: 3.3.37
System install date: 2023-05-03
Last full system update: 2025-03-03 ↻
