repeatedly getting this message on sudo pacman -Syu or really any terminal input
McFly: Upgrading McFly DB to version 3, please wait...thread 'main' panicked at 'McFly error: Unable to add cm
d_tpl to commands (duplicate column name: cmd_tpl)', src/history/schema.rs:41:17
note: run with RUST_BACKTRACE=1 environment variable to display a backtrace
searched and searched on google and duckduckgo and can only find people saying to google it and that the fix is out there. same results on this forum.
So there's no way to get rid of this error message? Did two fresh reinstalls and I'm getting the same thing, removing mcfly removes all theming and tools and makes this distro look like trash.
actually that doesn't really help considering McFly isn't a package that can be removed with pacman -R, I can only find it with octopi and the the file mentioned in the post I linked doesn't exist.
thanks so much for the help man but that just throws a whole neverending loop of crap about "fzf". I'll just check out manjaro, tired of messing with stuff.
