$ garuda-inxi
Kernel: 5.19.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=92f593d3-2105-4b14-970a-effb8cdf1c9c rw rootflags=subvol=@
quiet
cryptdevice=UUID=e30ff2cd-8fd9-473e-bd9c-99fc00554e62:luks-e30ff2cd-8fd9-473e-bd9c-99fc00554e62
root=/dev/mapper/luks-e30ff2cd-8fd9-473e-bd9c-99fc00554e62 quiet splash
Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.0 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Intel product: NUC7i7BNH v: J31153-311
serial: <superuser required> Chassis: type: 3 v: 2
Mobo: Intel model: NUC7i7BNB v: J31145-310 serial: <superuser required>
UEFI-[Legacy]: Intel v: BNKBL357.86A.0088.2022.0125.1102 date: 01/25/2022
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: full
Info: model: Intel Core i7-7567U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check gen: core 7 level: v3 built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1100 min/max: 400/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 1100 2: 1100 3: 1100 4: 1100 bogomips: 27999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel Iris Plus Graphics 650 driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: DP-1 empty: DP-2,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:5927 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: marco v: 1.26.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915 display-ID: :0
s-diag: 1165mm (45.88")
Monitor-1: DP-1 model: Samsung LU28R55 serial: <filter> built: 2021
res: 3840x2160 hz: 60 dpi: 154 gamma: 1.2 size: 632x360mm (24.88x14.17")
diag: 727mm (28.6") ratio: 16:9 modes: max: 3840x2160 min: 720x400
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
Sound Server-1: ALSA v: k5.19.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24fd
IF: wlp58s0 state: up mac: <filter>
bus-ID: 1-8:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 698.65 GiB used: 313.45 GiB (44.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO
250GB size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7
temp: 34.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 24.66 GiB
(10.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-e30ff2cd-8fd9-473e-bd9c-99fc00554e62
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 24.66
GiB (10.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 24.66
ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 24.66
ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C pch: 48.5 C mobo: N/A
Processes: 241 Uptime: 11h 35m wakeups: 31 Memory: 31.24 GiB used: 4.82 GiB
(15.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1370 libs: 436
tools: octopi,paru Shell: Bash v: 5.1.16 running-in: mate-terminal
inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-15
Last full system update: 2022-09-16 ↻
I can't find the desktop layout selector shown in this thread:
From that thread, "Familiar" is what I would have picked.
The MATE Tweak panel layout options (GNOME2/OpenSUSE/Fedora) is glitchy and moves the bottom bar to the top, requiring a "reset all panels" to fix.
If nothing else, I just want the start menu to be more like the "Familiar" screenshot.
