Hello everyone, I would like to ask if anyone here uses or has used MangoJuice instead of GOverlay to quickly configure MangoHud.
I don’t have much time right now and I would like to go play and see how it performs, which is why I’m asking, because I don’t want to have to manually modify the MangoHud settings.
Thank you and best regards.
Kernel: 6.16.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
root=UUID=1b079d8b-58a3-4533-8245-22b97207f1e1 rw rootflags=subvol=@ pcie_aspm=off quiet
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.18.0 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A serial: <superuser required>
Mobo: Gigabyte model: Z390 AORUS PRO-CF serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: F14b date: 06/12/2025
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xD (13)
microcode: 0x104
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4701 min/max: 800/5000 scaling: driver: intel_pstate governor: powersave
cores: 1: 4701 2: 4701 3: 4701 4: 4701 5: 4701 6: 4701 7: 4701 8: 4701 9: 4701 10: 4701 11: 4701
12: 4701 13: 4701 14: 4701 15: 4701 16: 4701 bogomips: 115200
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Gigabyte driver: nvidia v: 580.82.09
alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of 2025-08;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2,DP-3 empty: DP-1,HDMI-A-1,Unknown-2 bus-ID: 01:00.0
chip-ID: 10de:1e81 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 compositor: kwin_wayland
driver: X: loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 3926x2208 display-ID: 0
Monitor-1: DP-2 pos: top-right model: Asus ROG PG279Q serial: <filter> built: 2017 res:
mode: 2560x1440 hz: 120 scale: 125% (1.25) to: 2048x1152 dpi: 109 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: DP-3 pos: bottom-l model: Philips 191EL serial: <filter> built: 2010 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 memory: 7.81 GiB
display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 16 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 2080
SUPER driver: nvidia v: 580.82.09 device-ID: 10de:1e81 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM 20.1.8)
gpu: corectrl, nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D / Z-Series BlasterX AE-5
Plus] driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 1102:0012 class-ID: 0403
API: ALSA v: k6.16.8-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.4.8 status: active with:
1: pipewire-pulse status: active
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 3.18 TiB used: 1.63 TiB (51.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8 size: 931.51 GiB
fw-rev: P4CR313 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164 size: 1.82 TiB
fw-rev: CC27 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 251.62 GiB (54.1%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 620 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 251.62 GiB (54.1%) fs: btrfs
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 251.62 GiB (54.1%)
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 251.62 GiB (54.1%)
ID-1: swap-1 type: zram size: 62.72 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
System Temperatures: cpu: 34.0 C pch: 49.0 C mobo: 31.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0 fan-3: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 2.99
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 5.34 GiB (8.5%)
Processes: 392 Power: uptime: 33m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 25.02 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 258
Packages: pm: pacman pkgs: 1907 libs: 562 tools: octopi,pacseek,pamac,paru Compilers:
gcc: 15.2.1 Client: shell wrapper v: 5.3.3-release inxi: 3.3.39
Garuda (2.8.3-2):
System install date: 2024-08-17
Garuda release: 240428
Last full system update: 2025-09-21
Failed units: run-media-MULTIMEDIA.mount
23/24 checks run in 0.69 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Failed systemd services found: run-media-MULTIMEDIA.mount
