Ok so I searched for a similar topic but could not find one.
As the topic says mangohud and vkbasalt are not longer working, infact goverlay says its missing them.
I have tried to remove the packages and reinstall them using octopi and garuda gamer but it dose not fix it any insight into this would be great thanks.
Ankur
12 June 2023 00:03
2
Could you please post your garuda-inxi ?
ystem:
Kernel: 6.3.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=9030eb2e-c906-4b8d-8b6c-02c5b4605b1f rw rootflags=subvol=@
loglevel=3 nvidia-drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Gigabyte model: X570 GAMING X serial: N/A UEFI: American
Megatrends LLC. v: F37a date: 02/17/2022
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 min/max: 2200/4426 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
bogomips: 86231
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: eVga.com.
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-1,HDMI-A-1 empty: DP-2,DVI-D-1 bus-ID: 08:00.0 chip-ID: 10de:1f08
Device-2: Sunplus Innovation UHD 4K M3 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-3.4.1:8
chip-ID: 1bcf:2ced class-ID: 0102 serial: <filter>
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3440x2880 s-dpi: 110 s-size: 795x666mm (31.30x26.22")
s-diag: 1037mm (40.83")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,bottom
model: Samsung S34J55x serial: <filter> built: 2022 res: 3440x1440 dpi: 110
gamma: 1.2 size: 797x333mm (31.38x13.11") diag: 864mm (34") modes:
max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: top
model: Samsung S34J55x serial: <filter> built: 2022 res: 3440x1440 hz: 50
dpi: 110 gamma: 1.2 size: 797x333mm (31.38x13.11") diag: 864mm (34")
modes: max: 3440x1440 min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: eVga.com.
link-max: lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA Kraken Kitty Edition
lanes: 1 mode: 1.1 bus-ID: 7-3.3.1.3:14 chip-ID: 1532:0521 class-ID: 0300
Device-4: Sunplus Innovation UHD 4K M3 driver: snd-usb-audio,uvcvideo
Device-5: fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-4:4
chip-ID: 3142:0a80 class-ID: 0300 serial: <filter>
API: ALSA v: k6.3.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.71 status: n/a (root, process) with:
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0a2a
Local Storage: total: 5 TiB used: 681.28 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 510 SSD
ZP500GM30001 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STOSC014
temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 2y 155d 12h cycles: 1,093
read-units: 168,686,331 [86.3 TB] written-units: 143,334,989 [73.3 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUS724040ALE640
family: HGST Ultrastar 7K4000 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: A3B0 temp: 43 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 158d 4h cycles: 1093
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LX015-1U7172
family: FireCuda 2.5 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: SDM1 temp: 39 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 364d 3h cycles: 1926
read: 28.15 TiB written: 31.35 TiB Pre-Fail: reallocated sector: 100
threshold: 36 attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
used: 343.17 GiB (73.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 4.07 GiB (13.0%)
System Temperatures: cpu: 65.0 C mobo: 30.0 C gpu: nvidia temp: 47 C
Processes: 395 Uptime: 1h 27m wakeups: 0 Memory: available: 31.26 GiB
used: 6.21 GiB (19.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2085
pm: pacman pkgs: 2075 libs: 556 tools: octopi,pamac,paru pm: flatpak
pkgs: 10 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-06-05
Last full system update: 2023-06-11 ↻
filo
12 June 2023 04:59
4
This means a reboot is pending. You never can say…
Additionally, make sure to keep your system up-to-date with
garuda-update
You’ll probably get an error message on mangohud. If so, search in the forum and you’ll find several topics solved (with some variances in the approach).
If necessary, install packages using pacman. GUI-based package managers (like octopi) can create troubles in some cases, like this mangohud story.
Ok so I did all that still nothing any other thoughts?
neocrypter:
any other thoughts?
I think you need to provide more information, specifically because you are the only one here who can see the screen at the moment.
For example, this:
What happened with that? Paste the input and output of the command into the thread so we can see what is happening.
Did you find the information about resolving the mangohud conflict that filo mentioned? What intervention did you try? What were the results of your efforts?
“I did all that still nothing” is not a statement that provides any useful information.
sorry just woke up coffee still sinking in.
OK so there was no error when updating at all, I know when I launch goverlay it has a little red icon in the bottom right that says missing mango hud, when I try to launch mango hud in the steam launch options the game launches but mangohud is not preset on the screen. I did switch kernels back to the default zen kernel when this first started I had been testing the chachy bore kernel to see if I noticed any improvements in performance like they boast. But since then I have re-installed mangohud and its dependency as well as I ran a full package re-install from the garuda assistant.
i finally figured it out i had to install glu must have been removed when i un-installed and didnt get picked up as a dependency when i reinstalled
sudo pacman -S glu
system
Closed
15 June 2023 23:46
9
