Mango hud freezes on heroic launcher and not on wine
  Kernel: 6.12.1-1-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore
    root=UUID=6a89eaea-308f-4abd-9fcb-ab5da7653d04 rw rootflags=subvol=@
    quiet resume=UUID=b465697a-8524-4f00-a34b-323b7b836c83 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_wayland vt: 1 dm: SDDM Distro: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LU_FX566LU
  Mobo: ASUSTeK model: FX506LU v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: FX506LU.310
    date: 11/26/2021
  ID-1: BAT1 charge: 80.4 Wh (99.9%) condition: 80.5/90.0 Wh (89.5%)
    volts: 17.3 min: 15.4 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: not charging
  Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
  Speed (MHz): avg: 4299 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4299 2: 4299 3: 4299 4: 4299 5: 4299 6: 4299
    7: 4299 8: 4299 bogomips: 39999
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
    active: none off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
    driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
    empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 13d3:56a2
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.7-arch1.1
    device-ID: 8086:9bc4 memory: 7.55 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 15 device: 0 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.2.7-arch1.1
    device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: NVIDIA GeForce GTX 1660 Ti driver: nvidia
    v: 565.57.01 device-ID: 10de:2191 surfaces: xcb,xlib,wayland device: 2
    v: 24.2.7-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
  API: ALSA v: k6.12.1-1-cachyos-bore status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
    lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
  Local Storage: total: 1.4 TiB used: 563.39 GiB (39.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA1T0QFD
    lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 38.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: A-Data model: SX6000PNP
    lanes: 4 tech: SSD serial: <filter> fw-rev: VC0S036H temp: 29.9 C
  ID-1: / raw-size: 936.57 GiB size: 936.57 GiB (100.00%)
    used: 563.37 GiB (60.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 28.1 MiB (9.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 936.57 GiB size: 936.57 GiB (100.00%)
  ID-4: /var/log raw-size: 936.57 GiB size: 936.57 GiB (100.00%)
  ID-5: /var/tmp raw-size: 936.57 GiB size: 936.57 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.45 GiB used: 723.7 MiB (4.6%)
    max-streams: 8 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 61.0 C pch: 56.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Memory: total: 16 GiB available: 15.45 GiB used: 5.74 GiB (37.1%)
  Processes: 313 Power: uptime: 1h 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
  Packages: 2093 pm: pacman pkgs: 2081 libs: 583 tools: octopi,paru,yay
    pm: flatpak pkgs: 12 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
    default: Zsh v: 5.9 running-in: kitty inxi: 3.3.36
  System install date:     2024-09-17
  Last full system update: 2024-11-26
  Failed units:            nmb.service
in game screen shot
what i see from my monitor
SOLVED installed mixsets mod and it somehow fixed it
