Hello fellow garuda users, i have been using garuda KDE since one year. I recently needed to extensively use the man pages but my man pages are not rendering properly. I have no idea how i can describe this to google but heres what my man pages look like. This is the output of "man 2 open"
4mopen24m(2) System Calls Manual 4mopen24m(2)
1mNAME0m
This happens on every terminal emulator. Only alacritty running the bash shell can render the man pages properly. I have tried changing konsole's font to other mono spaced fonts but it dosent display properly.
Posting here if anyone got a solution.
Heres my inxi:
Kernel: 6.4.7-zen1-3-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=51bf01b2-746d-476e-bd26-5bec92e9a65c rw rootflags=subvol=@
quiet rd.luks.uuid=d14229a2-9ee7-4854-a0f6-0c8cdc165a2e quiet
clearcpuid=514
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Laptop System: Dell product: Inspiron 5515 v: 1.16.0
serial: <superuser required> Chassis: type: 10 v: 1.16.0
Mobo: Dell model: 0KDKG8 v: A00 serial: <superuser required> UEFI: Dell
v: 1.16.0 date: 04/12/2023
ID-1: BAT0 charge: 44.1 Wh (100.0%) condition: 44.1/54.0 Wh (81.7%)
volts: 16.8 min: 15.0 model: SMP-COS3.66 DELL XDY9K14 type: Li-poly
serial: <filter> status: full
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1536 high: 1915 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
3: 1397 4: 1400 5: 1400 6: 1400 7: 1400 8: 1397 9: 1652 10: 1764 11: 1915
12: 1640 13: 1800 14: 1615 15: 1607 16: 1397 bogomips: 57489
Device-1: AMD Lucienne vendor: Dell driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 66.0 C
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0c45:6725
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.7-zen1-3-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.7-zen1-3-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
IF-ID-1: enp3s0f3u4 state: up speed: 425 Mbps duplex: half mac: <filter>
IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-3: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:5 chip-ID: 8087:0029
Local Storage: total: 476.94 GiB used: 253.68 GiB (53.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC711 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 41002131 temp: 39.9 C
ID-1: / raw-size: 281.62 GiB size: 281.62 GiB (100.00%)
used: 113.66 GiB (40.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-d14229a2-9ee7-4854-a0f6-0c8cdc165a2e
used: 42.6 MiB (44.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 281.62 GiB size: 281.62 GiB (100.00%)
ID-4: /var/log raw-size: 281.62 GiB size: 281.62 GiB (100.00%)
ID-5: /var/tmp raw-size: 281.62 GiB size: 281.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.98 GiB used: 1.5 GiB (10.0%)
System Temperatures: cpu: 58.0 C mobo: 47.0 C gpu: amdgpu temp: 66.0 C
Fan Speeds (RPM): cpu: 4641
Processes: 407 Uptime: 7h 41m wakeups: 62208 Memory: total: 16 GiB
note: est. available: 14.98 GiB used: 9.41 GiB (62.8%) Init: systemd v: 254
pm: pacman pkgs: 1443 libs: 464 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-08-04
Last full system update: 2023-08-05 ↻
