Hello fellow Garudites / Garudans (not sure what we are called). I recently migrated to Garuda after the amazing Erik Dubois stepped down from my previous Arch distro, Arco Linux.
I was attracted to Garuda after trying it out and seeing the high level of passion put into your default configs, user-level helper apps, and the sick look of Dr460nized. As soon as I saw that you had contributed with the legendary EliverLara on the theming, I had a good feeling.
Anyway, one of the things I can’t live without is the variety wallpaper changer, which does not work by default on Garuda (at least not on Dr460nized). I finally decided to see if I could find out why, and am happy to say it was not too difficult to figure out (spoiler alert - it’s the active blur plugin).
I submitted a PR to variety, but while I am waiting on that to get reviewed I thought I would post here in case someone else was suffering without their wallpaper fetcher / changer. The changes needed to make variety work with active blur can be seen here.
Also, after going through the Garuda wiki I noticed some minor things, so if any of the mods could give me rights to contribute I would appreciate it.
And of course here is my garuda-inxi if it is helpful.
Kernel: 6.18.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=36f55943-52b4-46ba-a4f4-6ddfd201231e rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
wm: kwin_wayland tools: xscreensaver,xscreensaver-systemd vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.M0 date: 06/28/2023
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3577 min/max: 582/5086 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3577 2: 3577 3: 3577
4: 3577 5: 3577 6: 3577 7: 3577 8: 3577 9: 3577 10: 3577 11: 3577 12: 3577
13: 3577 14: 3577 15: 3577 16: 3577 17: 3577 18: 3577 19: 3577 20: 3577
21: 3577 22: 3577 23: 3577 24: 3577 25: 3577 26: 3577 27: 3577 28: 3577
29: 3577 30: 3577 31: 3577 32: 3577 bogomips: 217588
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3
code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
Writeback-1 bus-ID: 2f:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Monitor-1: HDMI-A-1 model: LG (GoldStar) TV SSCR2 serial: <filter>
built: 2022 res: mode: 4096x2160 hz: 120 scale: 100% (1) dpi: 61 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 21.1.6 DRM 3.64 6.18.2-zen2-1-zen) device-ID: 1002:744c
memory: 19.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 25.3.2-arch1.1
device-ID: 1002:744c surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.2-arch1.1 (LLVM
bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Cambridge Silicon Radio B10PRO
lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0a12:1004 class-ID: 0300
Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.18.2-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 26:00.0
IF: enp38s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
Local Storage: total: 3.64 TiB used: 1.73 TiB (47.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 Plus
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT4P1.2 temp: 41.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Seagate
model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
fw-rev: 614600WD temp: 48.9 C scheme: GPT
ID-1: / raw-size: 1.34 TiB size: 1.34 TiB (100.00%) used: 203.44 GiB (14.8%)
used: 15.6 MiB (5.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.34 TiB size: 1.34 TiB (100.00%)
used: 203.44 GiB (14.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 1.34 TiB size: 1.34 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.34 TiB size: 1.34 TiB (100.00%)
ID-1: swap-1 type: zram size: 125.7 GiB used: 21.2 MiB (0.0%)
System Temperatures: cpu: 60.5 C mobo: N/A gpu: amdgpu temp: 64.0 C
mem: 65.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 519
Memory: total: 128 GiB note: est. available: 125.7 GiB
used: 18.73 GiB (14.9%)
Processes: 817 Power: uptime: 9h 50m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.27 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1871 libs: 500 tools: octopi,pacseek,paru,yay
Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.2.1
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-12-09
Garuda release: 251103
Last full system update: 2025-12-27 ↻
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
25/26 checks run in 0.66 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
