Alright so… I am a newbie after all this time xD long story short, I bought an RX580 and I need Cycles to use it. I’ve come to know that rocm can make both work with each other and so my quest began, and if anyone could give me a hand I would pretty much appreciate it!
First thing I tried was putting my users in the video and render groups and then installing all the packages listed on
https://wiki.archlinux.org/title/GPGPU#ROCm
under 4 and 4.1, but nothing from 4.2-3-4
should I install those? Maybe give another try?
Well after that didn’t work: I looked up some tutorials and found this one
https://phazertech.com/tutorials/rocm.html
Which seemed pretty reliable, but I had to uninstall all of the packages from the wiki and install
rocm-hip-sdk
opencl-amd
And so I did. Noticed just now I forgot to installamdgpu-dkms
, I’m gonna try it right after posting and if the post is not deleted, regard it as not the solution please.
I also made the following changes
bash
sudo tee --append /etc/ld.so.conf.d/rocm.conf <<EOF
/opt/rocm/lib
/opt/rocm/lib64
EOF
sudo ldconfig
export PATH=$PATH:/opt/rocm-5.7/bin:/opt/rocm-5.7/opencl/bin
I also edited my ~/.profile and added the following line:
export HSA_OVERRIDE_GFX_VERSION=10.3.0
But yet Cycles refuses to work with me. I am clearly doing something wrong, or maybe idk whats happening. When I put rocminfo, the terminal outputs this:
Accessible by all: TRUE
Pool 2
Segment: GLOBAL; FLAGS: KERNARG, FINE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
Alloc Alignment: 4KB
Pool 3
Segment: GLOBAL; FLAGS: COARSE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
ISA Info:
Agent 2
Uuid: GPU-XX
Marketing Name: AMD Radeon RX 580 2048SP
Vendor Name: AMD
Feature: KERNEL_DISPATCH
Profile: BASE_PROFILE
Float Round Mode: NEAR
Max Queue Number: 128(0x80)
Queue Min Size: 64(0x40)
Queue Max Size: 131072(0x20000)
Queue Type: MULTI
Node: 1
Device Type: GPU
Cache Info:
L1: 16(0x10) KB
Chip ID: 28639(0x6fdf)
ASIC Revision: 1(0x1)
Cacheline Size: 64(0x40)
Max Clock Freq. (MHz): 1284
BDFID: 256
Internal Node ID: 1
Compute Unit: 32
SIMDs per CU: 4
Shader Engines: 4
Shader Arrs. per Eng.: 1
WatchPts on Addr. Ranges:4
Coherent Host Access: FALSE
Features: KERNEL_DISPATCH
Fast F16 Operation: TRUE
Wavefront Size: 64(0x40)
Workgroup Max Size: 1024(0x400)
Workgroup Max Size per Dimension:
x 1024(0x400)
y 1024(0x400)
z 1024(0x400)
Max Waves Per CU: 40(0x28)
Max Work-item Per CU: 2560(0xa00)
Grid Max Size: 4294967295(0xffffffff)
Grid Max Size per Dimension:
x 4294967295(0xffffffff)
y 4294967295(0xffffffff)
z 4294967295(0xffffffff)
Max fbarriers/Workgrp: 32
Packet Processor uCode:: 730
SDMA engine uCode:: 58
IOMMU Support:: None
Pool Info:
Pool 1
Allocatable: TRUE
Alloc Granule: 4KB
Accessible by all: FALSE
Pool 2
Segment: GLOBAL; FLAGS: EXTENDED FINE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
Pool 3
Segment: GROUP
Allocatable: FALSE
Alloc Granule: 0KB
Alloc Alignment: 0KB
ISA Info:
ISA 1
Machine Models: HSA_MACHINE_MODEL_LARGE
Profiles: HSA_PROFILE_BASE
Default Rounding Mode: NEAR
Fast f16: TRUE
x 1024(0x400)
y 1024(0x400)
z 1024(0x400)
FBarrier Max Size: 32
*** Done ***
And that is all I have tried for now. A bit messy, right? Yeah, I’m totally lost on this one. Please send help xD
Edit:
garuda-update amdgpu-dkms
[sudo] password for aori:
garuda is up to date
core is up to date
extra is up to date
multilib 139.2 KiB 557 KiB/s 00:00 [----------------------------------------------] 100%
chaotic-aur 2.6 MiB 3.19 MiB/s 00:01 [----------------------------------------------] 100%
DEB_Arch_Extra 7.3 KiB 10.5 KiB/s 00:01 [----------------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
DEB_Arch_Extra downloading...
--> Applying keyring updates before starting full system update..
warning: archlinux-keyring-20231222-1 is up to date -- skipping
error: could not parse package description file 'haskell-hie-bios-0.11.0-70/desc' from db 'extra'
error: could not read db 'extra' (Truncated input file (needed 1024 bytes, only 0 available))
warning: chaotic-keyring-20230616-1 is up to date -- skipping
warning: garuda-hotfixes-1.1.2-1 is up to date -- skipping
there is nothing to do
error: target not found: amdgpu-dkms
Oops, almost forgot:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "pt_BR.UTF-8",
LC_NAME = "pt_BR.UTF-8",
LC_MONETARY = "pt_BR.UTF-8",
LC_PAPER = "pt_BR.UTF-8",
LC_IDENTIFICATION = "pt_BR.UTF-8",
LC_TELEPHONE = "pt_BR.UTF-8",
LC_MEASUREMENT = "pt_BR.UTF-8",
LC_TIME = "pt_BR.UTF-8",
LC_NUMERIC = "pt_BR.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.6.14-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=33da784c-6400-4145-99e3-93bc3c7463b2 rw rootflags=subvol=@
quiet
cryptdevice=UUID=5b16040e-5d39-4cd0-80b7-423ffe50eaff:luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
root=/dev/mapper/luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
Desktop: LXQt v: 1.4.0 tk: Qt v: 5.15.12 info: cairo-dock, lxqt-panel
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME H310M-E R2.0/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1605
date: 07/14/2020
Info: model: Intel Core i3-8100 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF4
desc: 1x6 MiB
Speed (MHz): avg: 1500 high: 3600 min/max: 800/3600 scaling:
driver: intel_pstate governor: performance cores: 1: 3600 2: 800 3: 800
4: 800 bogomips: 28808
Device-1: AMD Polaris 20 XL [Radeon RX 580 2048SP] driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
DP-3, DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:6fdf class-ID: 0300
temp: 38.0 C
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,vesa
alternate: fbdev dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.13x7.99")
s-diag: 412mm (16.24")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: TV PHILCO serial: <filter>
built: 2015 res: 1360x768 hz: 60 dpi: 49 gamma: 1.06
size: 708x398mm (27.87x15.67") diag: 484mm (19.1") ratio: 5:4, 4:3 modes:
max: 1360x768 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 2048SP (radeonsi
polaris10 LLVM 16.0.6 DRM 3.54 6.6.14-1-lts) device-ID: 1002:6fdf
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 2048SP (RADV POLARIS10) driver: mesa radv v: 23.3.4-arch1.2
device-ID: 1002:6fdf surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.4-arch1.2 (LLVM
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.6.14-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.78 TiB used: 348.51 GiB (12.2%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: Sb10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: G00A scheme: GPT
ID-1: / raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
used: 348.28 GiB (62.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%)
used: 242.2 MiB (4.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-4: /var/log raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1716
Processes: 252 Uptime: 23m wakeups: 0 Memory: total: 16 GiB
available: 15.56 GiB used: 4.1 GiB (26.3%) Init: systemd v: 255
Packages: 1822 pm: pacman pkgs: 1765 libs: 507 tools: pamac,paru pm: flatpak
pkgs: 57 Shell: Bash v: 5.2.26 running-in: qterminal inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-28
Last full system update: 2024-01-28
