Help cannot make a Boot usb anymore
Help i have tried all there vision of Garuda using KDE but i cannot make a usb that works
i am using Rufus on Windows 10 and even 11 2 diffrent machine jusy to make the usb
once Rufus is done i cannot read the usb
So i tried to download Fedora 42 use Rufus and bang no problem
is ther eany sepecial tricks to do
I have also tried BlaenEthcer and Ventroy
not working 2 driffetnt computers and 2 differet memory sticks still no luck
are the ISO files okay
in the past i used Rufus with no issues
i have tried every Boot Ventrry,En
No,
think on right settings inside bios
Fast boot off, secure boot off, ahci, uefi not csm etc
Use the latest ventoy for the usb stick.
Default press f11 to boot the stick ( or change inside the bios the boot order) → use grub2 option if you install a iso from 2025-03-08
→ use open driver → the live boot should function. Try a different usb port is also possible.
But all this is to read (example) there:
of course yes, but you can check the iso perhaps the download file is the issue.
