If I want to install any AUR package or invoke makepkg manually I get the following errors:
==> FEHLER: $SRCEXT does not contain a valid package suffix (needs '.src.tar*', got '')
==> FEHLER: $PKGEXT does not contain a valid package suffix (needs '.pkg.tar*', got '')
After some googling I found that I can set vars inline, which brought me to this:
SRCEXT='.src.tar*' PKGEXT='.pkg.tar*' makepkg -s --install
That throws this error:
==> FEHLER: paru steht für die ''-Architektur nicht zur Verfügung.
I can set more vars inline just needing to set more vars.
Further searching made me realize, that makepkg.conf is empty and so no vars are set at all! I tried re-installing pacman, base-devil, etc but the config file simply isnt created and I dont want to do it manually. I have no idea, why exactly it magically stopped working, at first I thought it could have been the switch from zsh to fish some time ago and thus some vars are not set, but I didnt find anything in that direction.
Maybe someone experienced the same issue and got some hint on how to solve this.
Garuda INXI
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5702d322-4da7-469d-adda-63a16266e7a2 rw rootflags=subvol=@
quiet resume=UUID=9005141b-26fc-4444-9334-a396c674ce84 loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 82JQ v: Legion 5 Pro 16ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ACH6H
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> part-nu: LENOVO_MT_82JQ_BU_idea_FM_Legion 5
Pro 16ACH6H uuid: <superuser required> UEFI: LENOVO v: GKCN60WW
date: 03/07/2023
ID-1: BAT0 charge: 73.3 Wh (100.0%) condition: 73.3/80.0 Wh (91.6%)
volts: 17.3 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: full cycles: 186
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1108 min/max: 400/4280 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1108 2: 1108 3: 1108
4: 1108 5: 1108 6: 1108 7: 1108 8: 1108 9: 1108 10: 1108 11: 1108 12: 1108
bogomips: 79053
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2560
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: eDP-1 model: California Institute of eDP-1-0x1609 built: 2021
res: mode: 2560x1600 hz: 165 scale: 100% (1) dpi: 188 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 2560x1600
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: N/A device-ID: 10de:2560
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 7 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 297.28 GiB (62.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 50.9 C
ID-1: / raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
used: 296.99 GiB (64.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 299.4 MiB (100.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
ID-4: /var/log raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 1.02 GiB (6.6%)
ID-2: swap-2 type: partition size: 17.02 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 59.4 C mobo: 46.0 C
Memory: total: 16 GiB available: 15.47 GiB used: 4.71 GiB (30.5%)
Processes: 344 Power: uptime: 22h 29m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 4 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2271 libs: 578 tools: octopi,paru,yay
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-01-21
Last full system update: 2025-01-29 ↻
