Answer: I wasn’t able to do makepkg, because i don’t know why but go wasm’t installed
I downloaded a file from github and when i use makepkg it says it doesn’t exist.
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9a32edc4-ec1a-4a8b-aea5-f9d1c3bcfc11 rw rootflags=subvol=@
Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: Micro-Star product: Prestige 16 A12UD v: REV:1.0
Mobo: Micro-Star model: MS-1592 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E1592IMS.10D date: 03/29/2023
ID-1: BAT1 charge: 72.8 Wh (100.0%) condition: 72.8/80.3 Wh (90.8%)
volts: 17.0 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: 12th Gen Intel Core i7-1280P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x430
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 418 high: 500 min/max: 400/4700:4800:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 490 6: 400 7: 500 8: 400 9: 495 10: 400 11: 485 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 79872
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 4 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0
class-ID: 0302
Display: wayland server: Xwayland v: 23.2.2 compositor: sway v: 1.8.1
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: AU Optronics 0xdb95 built: 2021 res: 2560x1600
hz: 165 dpi: 189 gamma: 1.2 scale: 1.29999995231628
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
modes: 2560x1600
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a6 surfaces: xcb,xlib,wayland device: 1 type: cpu
vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.4:3
IF: enp0s20f0u2u4 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 953.87 GiB used: 9.65 GiB (1.0%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7601Q temp: 31.9 C scheme: GPT
ID-1: / raw-size: 75.71 GiB size: 75.71 GiB (100.00%) used: 9.62 GiB (12.7%)
used: 30.7 MiB (32.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
used: 9.62 GiB (12.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
ID-5: /var/tmp raw-size: 75.71 GiB size: 75.71 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
Src: /sys System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 369 Uptime: 8m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.32 GiB used: 2.28 GiB (14.9%) Init: systemd v: 254
pm: pacman pkgs: 1276 libs: 401 tools: paru Shell: fish v: 3.6.1
running-in: alacritty inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-12-01
Last full system update: 2023-12-03
