Hello, i new in Garuda Linux i have an issue for window button, when it's got maximized then the window button is disappear, i can't resize, close, or minimize the Window
Please Help Garuda Team
Thank you
Thank you
Which edition are you using?
Also, try switching from wayland to xorg, if you have wayland as session.
And welcome to community.
Did you do something with latte?
Yes i do, i delete the upper panel
Sorry to ask
Well, go to kde settings and see if they are disabled in windows decoration. I forgot how to show them. Search on search engine.
Actually, we hid them on maximize so that they appear on Latte. It looked cool. But as you removed it, the buttons are hidden.
Actually it's quite cool but it will be a problem for a people who use 2 monitors
I had the same problem and I fixed it by going to Garuda Assistant and hitting restore default configs.
I also have two monitors so I fixed that problem by right-clicking on the desktop at the second monitor, hitting add panel and clicking application menu bar. Then I edited the second panel as needed
