Make ID card reader work in Firefox
Hello,
I own an ID card reader (for Estonian ID) and I would like to be able to sign stuff in Firefox. I have PKCS11 loader extension installed but it seems to be disabled even on pages where I can sign documents in the browser.
I have the following packages installed:
local/acsccid 1.1.10-1
  PC/SC driver that supports ACS CCID smart card readers.
local/ccid 1.5.2-1
  A generic USB Chip/Smart Card Interface Devices driver
local/opensc 0.23.0-1
  Tools and libraries for smart cards
local/chrome-token-signing 1:1.1.5.547-1
  Chrome and Firefox extension for signing with your eID on the web
local/pcsc-perl 1.4.14-14
  A Perl Module for PC/SC SmartCard access
local/pcsc-tools 1.6.2-1
  PC/SC Architecture smartcard tools
local/pcsclite 2.0.0-1
  PC/SC Architecture smartcard middleware library
local/libdigidocpp 3.16.0.1442-1
  Library for creating, signing and verification of digitally signed documents, according to XAdES and XML-DSIG standards
local/qdigidoc4 4.4.0.4447-1
  DigiDoc4 Client is an application for digitally signing and encrypting documents; the software includes functionality to manage Estonian ID-card - change pin codes, update certificates etc.
Both pcscd socket and systemd services are enabled:
[sudo] password for v1rtl:
● pcscd.socket - PC/SC Smart Card Daemon Activation Socket
Loaded: loaded (/usr/lib/systemd/system/pcscd.socket; enabled; preset: disabled)
Active: active (running) since Fri 2023-09-08 12:33:16 EEST; 32min ago
Triggers: ● pcscd.service
Listen: /run/pcscd/pcscd.comm (Stream)
CGroup: /system.slice/pcscd.socket
sept  08 12:33:16 Asus systemd[1]: Listening on PC/SC Smart Card Daemon Activation Socket.
● pcscd.service - PC/SC Smart Card Daemon
Loaded: loaded (/usr/lib/systemd/system/pcscd.service; indirect; preset: disabled)
Active: active (running) since Fri 2023-09-08 12:35:01 EEST; 31min ago
TriggeredBy: ● pcscd.socket
Docs: man:pcscd(8)
Main PID: 2571 (pcscd)
Tasks: 11 (limit: 37895)
Memory: 6.7M
CPU: 388ms
CGroup: /system.slice/pcscd.service
└─2571 /usr/bin/pcscd --foreground --auto-exit
sept  08 12:35:01 Asus systemd[1]: Started PC/SC Smart Card Daemon.
sept  08 12:35:01 Asus (pcscd)[2571]: pcscd.service: Referenced but unset environment variable evaluates to a>
DigiDoc4 client works completely fine, it detects the card and I'm able to sign documents. Okular also works with PDF signing. But on Firefox for whatever reason the extension is always disabled. I tried installing from Firefox Addon store, and building from source and importing xpi, none worked.
Here's how it looks when it's disabled:
For instance I can't log in to eesti.ee:
pcsc_scan output:
PC/SC device scanner
V 1.6.2 (c) 2001-2022, Ludovic Rousseau <ludovic.rousseau@free.fr>
Using reader plug'n play mechanism
Scanning present readers...
0: Alcor Micro AU9540 00 00
Fri Sep  8 13:11:11 2023
Reader 0: Alcor Micro AU9540 00 00
Event number: 1
Card state: Card inserted, Shared Mode,
+ TS = 3B --> Direct Convention
+ T0 = DB, Y(1): 1101, K: 11 (historical bytes)
TA(1) = 96 --> Fi=512, Di=32, 16 cycles/ETU
250000 bits/s at 4 MHz, fMax for Fi = 5 MHz => 312500 bits/s
TC(1) = 00 --> Extra guard time: 0
TD(1) = 80 --> Y(i+1) = 1000, Protocol T = 0
TD(2) = B1 --> Y(i+1) = 1011, Protocol T = 1
TA(3) = FE --> IFSC: 254
TB(3) = 45 --> Block Waiting Integer: 4 - Character Waiting Integer: 5
TD(3) = 1F --> Y(i+1) = 0001, Protocol T = 15 - Global interface bytes following
TA(4) = 83 --> Clock stop: state H - Class accepted by the card: (3G) A 5V B 3V
Category indicator byte: 00 (compact TLV data object)
Tag: 1, len: 2 (country code, ISO 3166-1)
Country code: 23 3F
Tag: 5, len: 3 (card issuer's data)
Card issuer data: 65 49 44
Mandatory status indicator (3 last bytes)
LCS (life card cycle): 0F (unknown)
SW: 9000 (Normal processing.)
+ TCK = F1 (correct checksum)
Possibly identified card (using /usr/share/pcsc/smartcard_list.txt):
Estonia ID-card (eID)
https://id.ee
my garuda-inxi:
Kernel: 6.4.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=31891f4d-4b7f-4e61-a0da-e72715325014 rw rootflags=subvol=@
"acpi.dyndbg=file drivers/acpi/x86/s2idle.c +p" quiet quiet
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Laptop System: ASUSTeK product: ROG Zephyrus G16 GU603VV_GU603VV
Mobo: ASUSTeK model: GU603VV v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GU603VV.308 date: 04/21/2023
ID-1: BAT0 charge: 24.7 Wh (29.0%) condition: 85.2/90.0 Wh (94.7%)
power: 24.0 W volts: 14.5 min: 15.9 model: AS3GWAF3KC GA50358 type: Unknown
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4119
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2772 high: 3000 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3000 2: 3000 3: 3000
4: 3000 5: 670 6: 3000 7: 784 8: 3000 9: 3000 10: 3000 11: 3000 12: 3000
13: 3000 14: 3000 15: 3000 16: 3000 17: 3000 18: 3000 19: 3000 20: 3000
bogomips: 119840
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:a7a0
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:28e0
Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0408:30c3
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
Monitor-1: eDP-1 res: 2048x1280 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: Mesa Intel Graphics
(RPL-P) direct-render: Yes
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:51ca class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
API: ALSA v: k6.4.12-arch1-1 status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
vendor: ASUSTeK driver: N/A modules: r8169 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3a:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 953.87 GiB used: 148.34 GiB (15.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA1T0QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 33.9 C
used: 148.34 GiB (15.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.97 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2300
Processes: 412 Uptime: 28m wakeups: 2 Memory: total: 32 GiB note: est.
available: 30.97 GiB used: 9.04 GiB (29.2%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1608 libs: 485 tools: octopi,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.29
System install date:     2023-08-27
Last full system update: 2023-09-08 ↻
Failed units:            nmb.service
It looks like it does not have permission to read the page. Have you attempted to change the extension settings?
I managed to solve it by installing web-eid-firefox AUR package. Turns out web eID has to be installed or else the extension won't work.
