The built in speakers and headphone jack don't work until I zap the PRAM but upon restarting without a PRAM zap the audio isn't' working again. It's shown as input and output devices (Speakers/Headphones) in System Settings but I never hear anything in any application. The audio via bluetooth or Thunderbolt (to HDMI) always works.
I've updated the system just now, I've done some searching to no avail, checking the Arch Wiki and forums, etc.
I have access to hundreds of these incredibly decent machines and I want to get them in the hands of people who have never used FOSS before but this one issue is the only thing holding me back. I would even settle for automatically resetting the PRAM at every startup, if that's possible.
Here is the garuda-inxi from a working state:
Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e0430201-0931-4d49-a5a8-f8a1445e4ab0 rw [email protected]
resume=UUID=ae0cdb3c-2994-4db6-8822-7960e6e25fe8 loglevel=3
mem_sleep_default=s2idle ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-937CB26E2E02BB01
Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2
serial: <superuser required> UEFI: Apple v: 430.120.6.0.0 date: 03/16/2022
ID-1: BAT0 charge: 49.2 Wh (96.9%) condition: 50.8/54.3 Wh (93.5%)
volts: 8.6 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: charging cycles: 236
Info: model: Intel Core i5-5350U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1800 min/max: 500/2900 scaling: driver: intel_cpufreq
governor: performance cores: 1: 1800 2: 1800 3: 1800 4: 1800 bogomips: 14400
Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1626
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: eDP-1 model: Apple Color LCD built: 2015 res: 1440x900 hz: 60
dpi: 128 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1440x900
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel HD Graphics 6000 (BDW
GT3) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570
class-ID: 0480
Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
address: <filter>
Local Storage: total: 233.76 GiB used: 41.98 GiB (18.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3A0Q scheme: GPT
ID-1: / raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
used: 41.98 GiB (18.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-4: /var/log raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 62.0 C pch: 71.0 C mobo: N/A
Processes: 227 Uptime: 2m wakeups: 2 Memory: 7.67 GiB used: 1.48 GiB (19.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 2134 libs: 585
tools: octopi,pamac,paru Shell: fish v: 3.6.0 running-in: konsole
inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2022-12-02
Last full system update: 2023-02-14
I took another garuda-inxi when it was broken and noticed one thing changed
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
Thanks for any help that may possibly be provided!
Edit: I've also reset the power manager (SMC) and the EUFI firmware is up to date as I've installed macOS 12.x on these.
