NVIDIA GeForce GT 750M Mac Edition
hello everyone. my graphic only show 2880x1800 and doesn’t support any other resolution.i do tones of stuffs but nothing work!!
when i maximize my windows the (close,maximize,minimize) bottums become small. my fonts are small but my titles are big. its f*#king wired.what can i do? its really bothering me
filo
16 February 2024 12:00
2
First of all, please provide your garuda-inxi, as required in the topic template.
We don’t know anything about your system.
CPU: quad core Intel Core i7-4870HQ (-MT MCP-)
speed/min/max: 1161/800/3700 MHz Kernel: 6.7.4-zen1-1-zen x86_64 Up: 1h 26m
Mem: 5.79/15.53 GiB (37.3%) Storage: 465.92 GiB (10.6% used) Procs: 289
Shell: fish inxi: 3.3.33
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6f26dbec-0a54-499a-9e48-320bad635cf9 rw rootflags=subvol=@
resume=UUID=91a5c7e0-cc3e-4eb8-8d9a-4a39cdcd56fb loglevel=3 ibt=off
Type: Laptop System: Apple product: MacBookPro11,3 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-2BD1B31983FE1663
Mobo: Apple model: Mac-2BD1B31983FE1663 v: MacBookPro11,3
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 429.0.0.0.0 date: 12/02/2020
ID-1: BAT0 charge: 48.1 Wh (57.3%) condition: 84.0/95.4 Wh (88.0%)
volts: 10.7 min: 11.3 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 149
Info: model: Intel Core i7-4870HQ bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x46 (70) stepping: 1 microcode: 0x1C
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2025 high: 2780 min/max: 800/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2542 2: 800 3: 2780
4: 1800 5: 2495 6: 2495 7: 800 8: 2494 bogomips: 39908
Device-1: NVIDIA GK107M [GeForce GT 750M Mac Edition] vendor: Apple
driver: nvidia v: 390.157 alternate: nouveau,nvidia_drm non-free:
series: 470.xx+ status: legacy-active (EOL~2024-09-xx) arch: Kepler
code: GKxxx process: TSMC 28nm built: 2012-2018 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0fe9
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 2880x1800 s-dpi: 221 s-size: 331x211mm (13.03x8.31")
s-diag: 393mm (15.45")
Monitor-1: Unknown-1 mapped: DP-2 res: 2880x1800 hz: 60 dpi: 221
size: 331x207mm (13.03x8.15") modes: 2880x1800
API: EGL v: 1.5 platforms: gbm: drv: kms_swrast wayland: egl: N/A drv: N/A
API: OpenGL v: 4.5 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
glx-v: 1.4 direct-render: yes renderer: GeForce GT 750M/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: discrete-gpu
name: GeForce GT 750M driver: N/A device-ID: 10de:0fe9 surfaces: xcb,xlib
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM 16.0.6)
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:1570 class-ID: 0480
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
vendor: Apple driver: wl v: kernel modules: bcma pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.3:6
chip-ID: 05ac:8289 class-ID: fe01
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 465.92 GiB used: 54.05 GiB (11.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512F
size: 465.92 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: JA1Q scheme: GPT
ID-1: / raw-size: 49.8 GiB size: 49.8 GiB (100.00%) used: 42.13 GiB (84.6%)
fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 1000 MiB size: 93.84 GiB (9609.05%)
used: 3.2 MiB (0.0%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 29.3 GiB size: 29.3 GiB (100.00%)
used: 11.92 GiB (40.7%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-4: /var/log raw-size: 49.8 GiB size: 49.8 GiB (100.00%)
used: 42.13 GiB (84.6%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-5: /var/tmp raw-size: 49.8 GiB size: 49.8 GiB (100.00%)
ID-2: swap-2 type: partition size: 13.92 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 87.0 C mobo: N/A gpu: nvidia temp: 73 C
Memory: total: 16 GiB available: 15.53 GiB used: 3.25 GiB (20.9%)
Processes: 281 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1599 libs: 422 tools: octopi,paru,yay
Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2023-06-24
Last full system update: 2024-02-16
Relevant software: snapper(custom) NetworkManager dracut
Failed units: vmware.service
filo
17 February 2024 13:12
6
Have you tried changing resolution with nvidia-settings?
Additionally, it seems that your GPU is supported by the 470xx driver series
You might give it a try, but you’ll have to carefully remove the 390 drivers first.
yes. i try. but generally its not just about resolution. the font and sizes different in fullscreen and normal. the icons, texts,nothing is normal.
filo
18 February 2024 11:19
8
The resolution might be a known issue for your model.
Checking in the Arch wiki
https://wiki.archlinux.org/title/MacBookPro11,x#Graphics
There are instructions for your model, but a link provided in that Arch wiki article
I’ve been using 13.04 (raring ringtail) daily build on my macbook pro (rMBP) for a couple days now, and things have been working great so far. Definitely a major improvement over 12.10, and for a daily build it’s been pretty stable too.
Improved from...
although old and for Ubuntu, at the end says:
Only the native resolution (2880x1800) is available, which means the text is rather small
And the other issues might be related to this.
SGS
18 February 2024 11:33
9
Check if xft.dpi=120 or 144
is set in ~/.Xresources
. If not exist, use Kate.
Restart.
https://wiki.archlinux.org/title/HiDPI
filo
18 February 2024 11:36
10
If nothing else works, you could try section 5.4.1 or 5.4.2 in the Arch wiki article.
I just noticed that your model has also an Intel iGPU, although disabled by default, that you could try to activate as suggested.
system
Closed
3 March 2024 11:37
11
