Hello. Keyboard problem after update. Only numbers work instead of letters. MacBook 4.1 2008. Please tell me how to solve the issue. Thanks.
garuda-inxi:
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d589b821-530f-4a1f-8865-1926e3117901 rw [email protected]
resume=UUID=71f2e536-1730-4423-a486-8da00bd3ce32 loglevel=3
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Unknown System: Apple product: MacBook4,1 v: 1.0
serial: <superuser required> Chassis: type: 2 v: Mac-F22788A9
Mobo: Apple model: Mac-F22788A9 v: PVT serial: <superuser required>
UEFI: Apple v: MB41.88Z.00C1.B00.0802091535 date: 02/09/08
ID-1: BAT0 charge: 15.1 Wh (87.8%) condition: 17.2/45.4 Wh (37.9%)
volts: 12.3 min: 10.8 model: SONY ASMB013 type: Li-ion serial: N/A
status: full cycles: 52
Info: model: Intel Core2 Duo T8100 bits: 64 type: MCP arch: Core Yorkfield
family: 6 model-id: 0x17 (23) stepping: 6 microcode: 0x60F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 926 high: 1055 min/max: 800/2100 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1055 2: 798
bogomips: 8379
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: Intel Mobile GM965/GL960 Integrated Graphics vendor: Apple
driver: i915 v: kernel ports: active: LVDS-1 empty: DVI-D-1,SVIDEO-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:2a02 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 mapped: LVDS1 model: Apple 0x9c5f built: 2006
res: 1280x800 hz: 60 dpi: 112 gamma: 1.2 size: 290x180mm (11.42x7.09")
diag: 337mm (13.3") ratio: 16:10 modes: 1280x800
Device-1: Intel 82801H HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b class-ID: 0403
Device-1: Broadcom BCM4321 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: ssb pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4328 class-ID: 0280
IF: wls4 state: up mac: <filter>
Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2 v: 1.30
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000 bus-ID: 03:00.0
chip-ID: 11ab:436a class-ID: 0200
IF: ens5 state: down mac: <filter>
Device-1: Apple Bluetooth HCI type: USB driver: btusb v: 0.8 bus-ID: 3-1:3
chip-ID: 05ac:8205 class-ID: fe01
address: <filter>
Local Storage: total: 111.79 GiB used: 10.24 GiB (9.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s type: SSD
serial: <filter> rev: 61.3 scheme: GPT
ID-1: / raw-size: 103.11 GiB size: 103.11 GiB (100.00%)
used: 10.24 GiB (9.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 103.11 GiB size: 103.11 GiB (100.00%)
ID-4: /var/log raw-size: 103.11 GiB size: 103.11 GiB (100.00%)
ID-5: /var/tmp raw-size: 103.11 GiB size: 103.11 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.39 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 3.81 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 205 Uptime: 7m wakeups: 3 Memory: 3.81 GiB
used: 1.18 GiB (31.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1079 lib: 299 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-24
Last full system update: 2022-03-25
