here is my issue, the mac fans are not kicking on at all
not sure if this is normal.. is linux not really made for mac :
here is my specs again
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=1c063fc0-3542-471b-ae43-02258a0497a4 rw rootflags=subvol=@
resume=UUID=87bd4a68-f2ae-493f-84c9-7f7dcbd1f479 loglevel=3
Type: Laptop System: Apple product: MacBookAir7,1 v: 1.0 serial: <filter>
Chassis: type: 9 v: Mac-9F18E312C5C2BF0B serial: <filter>
Mobo: Apple model: Mac-9F18E312C5C2BF0B v: MacBookAir7,1 serial: <filter>
UEFI: Apple v: 430.140.3.0.0 date: 04/18/2022
ID-1: BAT0 charge: 35.3 Wh (99.7%) condition: 35.4/38.8 Wh (91.3%)
volts: 8.5 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 332
Info: model: Intel Core i5-5250U socket: BGA1168 (U3E1) note: check
bits: 64 type: MT MCP arch: Broadwell gen: core 5 built: 2015-18
process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1150 high: 1485 min/max: 500/2700 base/boost: 2500/1600
scaling: driver: intel_cpufreq governor: schedutil volts: 0.9 V
ext-clock: 25 MHz cores: 1: 920 2: 1485 3: 1189 4: 1006 bogomips: 12800
vulnerable
Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1626
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: Apple Color LCD built: 2011 res: 1366x768 hz: 60
dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67") diag: 294mm (11.6")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3) v: 4.6 Mesa
22.1.6 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb
v: 0.8 bus-ID: 1-3.3:7 chip-ID: 05ac:828f class-ID: fe01
Local Storage: total: 113 GiB used: 9.89 GiB (8.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SD0128F
family: SD/SM/TS...E/F/G SSDs size: 113 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 821 temp: 71 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 107d 14h cycles: 23594
ID-1: / raw-size: 104.49 GiB size: 104.49 GiB (100.00%) used: 9.89 GiB
(9.5%) fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
(0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 104.49 GiB size: 104.49 GiB (100.00%) used: 9.89
GiB (9.5%) fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 104.49 GiB size: 104.49 GiB (100.00%) used: 9.89
ID-5: /var/tmp raw-size: 104.49 GiB size: 104.49 GiB (100.00%) used: 9.89
ID-1: swap-1 type: zram size: 3.74 GiB used: 54 MiB (1.4%) priority: 100
ID-2: swap-2 type: partition size: 8.22 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 68.0 C pch: 67.5 C mobo: N/A
Processes: 211 Uptime: 9m wakeups: 2 Memory: 3.74 GiB used: 1.96 GiB
(52.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1165 lib: 295 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2022-08-13
Last full system update: 2022-08-13
and here is my other info:
coretemp-isa-0000
Adapter: ISA adapter
Package id 0:
temp1_input: 64.000
temp1_max: 105.000
temp1_crit: 105.000
temp1_crit_alarm: 0.000
Core 0:
temp2_input: 64.000
temp2_max: 105.000
temp2_crit: 105.000
temp2_crit_alarm: 0.000
Core 1:
temp3_input: 62.000
temp3_max: 105.000
temp3_crit: 105.000
temp3_crit_alarm: 0.000
BAT0-acpi-0
Adapter: ACPI interface
in0:
in0_input: 8.508
temp:
temp1_input: 37.900
curr1:
curr1_input: 0.000
curr1_average: 0.000
applesmc-isa-0300
Exhaust :
fan1_input: 1749.000
fan1_min: 1200.000
fan1_max: 6500.000
TB0T:
temp1_input: 37.500
TB1T:
temp2_input: 37.500
TB2T:
temp3_input: 36.000
TBXT:
temp4_input: 37.500
TC0E:
temp5_input: 64.750
TC0F:
temp6_input: 66.500
TC0P:
temp7_input: 57.750
TC1C:
temp8_input: 62.000
TC2C:
temp9_input: 61.000
TCGC:
temp10_input: 62.000
TCHP:
temp11_input: 55.500
TCMX:
temp12_input: 62.000
TCSA:
temp13_input: 62.000
TCXC:
temp14_input: 62.000
TH0A:
temp15_input: 71.500
TH0B:
temp16_input: 58.500
TH0C:
temp17_input: -127.000
TH0F:
temp18_input: -20.750
TH0R:
temp19_input: -20.500
TH0V:
temp20_input: 63.250
TH0a:
temp21_input: 71.500
TH0b:
temp22_input: 58.500
TH0c:
temp23_input: -127.000
THSP:
temp24_input: 49.750
TM0P:
temp25_input: 56.000
TPCD:
temp26_input: 66.000
TS2P:
temp27_input: 52.500
TW0P:
temp28_input: 50.000
Ta0P:
temp29_input: 53.750
Th1H:
temp30_input: 39.500
Tm0P:
temp31_input: 49.000
Ts0P:
temp32_input: 35.500
Ts0S:
temp33_input: 41.000
pch_wildcat_point-virtual-0
Adapter: Virtual device
temp1:
temp1_input: 66.500
BAT0-virtual-0
temp1:
temp1_input: 37.900
and then i get no fans detected at all in the fan control
is there going be issue with my mac or do i have to reinstall mac OS and stop using linux ?
