I have tested lxqt for days now tinkering. I don't know if it's a gui problem or not but, I searched everywhere unsuccessfully for the little wifi icon to put my password in. I had the idea that maybe I can download an app for wifi and I don't mean anything against octopi, I just have user error. so I put yay -S pamac-aur in the terminal and it just told me there was a command error. I used the same terminal command in kde so I know it works. Any help you guys can give will be greatly appreciated.
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b5ec8923-53ce-47fc-8cfa-a5237bb63e03 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: TOSHIBA product: TECRA Z40-C v: PT463U-08J02S
serial: <superuser required> Chassis: type: 10 v: Version 1.0
Mobo: TOSHIBA model: TECRA Z40-C v: Version A0
serial: <superuser required> UEFI-[Legacy]: TOSHIBA v: Version 6.80
date: 11/21/2018
ID-1: BAT1 charge: 26.6 Wh (56.5%) condition: 47.1/59.2 Wh (79.5%)
volts: 14.5 min: 14.5 model: G71C000GB510 type: Li-ion serial: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1677 high: 1701 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1700 2: 1610 3: 1700
4: 1701 bogomips: 19999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Toshiba driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14b7 built: 2014 res: 1366x768
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Toshiba
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Toshiba driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 15.41 GiB (6.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNTY256HDHP-00000
type: SSD serial: <filter> rev: 100Q scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 15.41 GiB (6.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C pch: 36.0 C mobo: N/A
Processes: 225 Uptime: 2m wakeups: 3 Memory: 7.67 GiB used: 2.35 GiB (30.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1230 libs: 311 tools: pamac,paru
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-06
Last full system update: 2022-11-10
Failed units: systemd backlight@leds:toshiba::kbd_backlight.service
