Hello!
The installation completes successfully. The new system boots ok . It connects to the internet. All good. However setup-assistant fails with "Update failed". This is happening with a fresh install, right after my first boot. Any subsequent attempt yields the same problem. I tested on different macbooks pro. Same result.
Any help would be really appreciated. Thanks!
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=c7e8e3b2-c31b-467d-b82f-b7d5c4e28bea rw rootflags=subvol=@
resume=UUID=35a61ea2-668c-47e9-8628-5f1a381dae64 loglevel=3
Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.6 info: cairo-dock, lxqt-panel
Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-94245B3640C91C81
Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1
serial: <superuser required> UEFI: Apple v: 87.0.0.0.0 date: 06/13/2019
ID-1: BAT0 charge: 42.1 Wh (98.1%) condition: 42.9/54.5 Wh (78.8%)
volts: 12.4 min: 10.9 model: DP bq20z451 type: Li-ion serial: N/A
status: charging cycles: 302
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 built: 2010-12 process: Intel 32nm family: 6
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 798 high: 800 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 798 3: 798
4: 798 bogomips: 21549
vulnerable
vendor: Apple driver: i915 v: kernel arch: Gen-6 process: Intel 32nm
built: 2011 ports: active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1,
HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0126
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 model: Apple 0x9ccb serial: <filter> built: 2009
res: 1280x800 hz: 60 dpi: 114 gamma: 1.2 size: 286x179mm (11.26x7.05")
diag: 337mm (13.3") ratio: 16:10 modes: 1280x800
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
IF: wlp3s0 state: dormant mac: <filter>
Device-3: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
bus-ID: 1-1.3:6 chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
IF: wlp0s26f7u1u3 state: up mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:9 chip-ID: 05ac:821a class-ID: fe01
Local Storage: total: 354.07 GiB used: 6.89 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Lexar model: 256GB SSD
type: SSD serial: <filter> rev: 117D scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 115.59 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 6.89 GiB
(3.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 6.89
GiB (3.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 6.89
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%) used: 6.89
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: 0.0 C
Processes: 235 Uptime: 4m wakeups: 2 Memory: 7.68 GiB used: 1.8 GiB (23.5%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pacman: 1154 lib: 305 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: qterminal inxi: 3.3.20
Garuda (2.6.7-1):
System install date: 2022-10-02
Last full system update: 2022-10-02
Just use ~~~ on first and last line, not million - ![]()
