Hello, people!! First things first:
inxi -Faz
System: Kernel: 5.14.6-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1409d596-84e3-4768-b0e5-996dc20bb2a5 rw
Desktop: LXQt 0.17.1 tk: Qt 5.15.2 info: cairo-dock, lxqt-panel wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: INTEL model: HM65DESK serial: <filter> UEFI: American Megatrends v: 4.6.5 date: 02/23/2019
CPU: Info: Dual Core model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F cache: L2: 4 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 21551
Speed: 1005 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 1005 2: 3192 3: 1679 4: 1282
Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1381 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.1x11.8") s-diag: 487mm (19.2")
Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 49 size: 708x398mm (27.9x15.7") diag: 812mm (32")
OpenGL: renderer: NVIDIA GeForce GTX 750/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.14.6-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Drives: Local Storage: total: 2.78 TiB used: 681.4 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s type: SSD serial: <filter> rev: Sb10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053 size: 2.73 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: G00A scheme: GPT
Partition: ID-1: / raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 287.73 GiB (73.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%) used: 235.9 MiB (4.1%) fs: vfat dev: /dev/sda2
maj-min: 8:2
ID-3: /home raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 287.73 GiB (73.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-4: /var/log raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 287.73 GiB (73.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-5: /var/tmp raw-size: 389.6 GiB size: 389.6 GiB (100.00%) used: 287.73 GiB (73.9%) fs: btrfs dev: /dev/sdb4
maj-min: 8:20
ID-1: swap-1 type: zram size: 3.79 GiB used: 19.2 MiB (0.5%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 28 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Info: Processes: 255 Uptime: 5m wakeups: 0 Memory: 3.79 GiB used: 2.39 GiB (63.1%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1886 lib: 527 flatpak: 0 Shell: fish v: 3.3.1
running-in: qterminal inxi: 3.3.06
So, my Lxqt-Kwin is acting weird. I didn't even update the last week and for the last couple of days I didn't even used the system, so I suppose it's not my fault. This is not the first time it happens as well, it occurred before, but I got to solve it by rolling back to a snapshot. This time, all snapshots appear with the same issue as the main system, which is:
My DE seems kinda broken. Some functionalities (mostly animations) are totally off and where the Cairo-dock appears it leaves a black strip 1.5x it's size. I still can change on which virtual desktop I am, and I still can go for some shortcuts like alt+tab to cycle trhough windows.
But other stuff like calling the menu with the super key or opening the virtual desktop grid I can't do. Didn't test all stuff, but I suppose this is enough info.
The system itself is working perfectly tho, I'm logged in right now and I could do a successful UPDATE. Sadly, the update didn't resolve my problem.
I was thinking, I saw a button on Garuda Assistant that says "reinstall all packages", but I thought it would be a little bit overkill. I also don't know which packages set up the DE so I can't do a reinstall only on it.
I also wanted to try to simply restart the DE, but I couldn't find any shortcut or command for lxqt-kwin, and logging in and out also have no effect.
Thanks for your attention and for all and any help in advance!
